06-22-2019 | #1 |
AC CV913C / 25098197 PCV VALVE
In case anyone needs these, this guy has 6 available.
https://www.ebay.com/itm/GENUINE-AC-...53.m1438.l2649 These are the ones that are hard to find. I just bought a couple. He accepted $6. each, Free shipping. They say AC Rochester on the valve as opposed to AC Delco like Jerry used to stock. They look identical to the AC Delco valves. I have no affiliation.
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
06-23-2019 | #2 | |
Re: AC CV913C / 25098197 PCV VALVE
06-23-2019 | #3 |
The body has identical dimensions. The AC Delco (Right) neck is 0.4 mm longer.
The AC Rochester valve (Left) also seems to be cadmium plated? (the greenish/pinkish finish seen best on the end view) vs. the bright finish on the AC Delco. Let me know if there is anything else you would like me to check.
06-23-2019 | #4 |
Seems correct part numbers are CV913C and CV769C.
Can someone confirm? eBay link takes me to CV727C. Last edited by secondchance; 06-23-2019 at 10:02 PM. |
06-23-2019 | #5 | |
Looks like the Ebay seller has sold the remaining 6
06-24-2019 | #6 | |
I'm not sure they are that hard to find as the AC DELCO 19303069 is $2.66 on Rock Auto. Last edited by spork2367; 06-24-2019 at 03:28 PM. |
06-26-2019 | #7 |
I have a few NOS AC CV913C PCV valves in the parts stash. Let me know if you need one.
06-26-2019 | #8 |
While we are on the subject of PCV valve. When I had head gasket problem, blowing steam and oil vapor would make the inside of PCV valves sticky. I would spray the inside with fuel injector cleaner, close the end with my thumb and shake it until inside was free and repeat as needed.
Do you think thins type of cleaning could make PCV valves function as intended for a long time? |
