![]() Join Date: Jul 2017
[SIGPIC][/SIGPIC] |
![]() Join Date: Nov 2013
I used to be able to drive up our open trailer but put 2x12's under the ramps and made sure the tongue was up. Now with the enclosed trailer I have to winch it up. I have the winch mounted in the floor so the cable stays low to the floor. I wrap a long axle strap around the front lower control arm then hook the cable hook to that. I leave it hooked up and then strap the car down with the points behind the front tire, and criss-cross over the rear batwing.
#3 | |
![]() Join Date: Jul 2005
I can pass a tow strap through the openings in the front on either side of the radiator support and can grab the cradle. It'll be above the chin spoiler so it shouldn't give me further problems in winching the car up. As for tying it down, I was going to pass the straps through the wheels using the protective sleeves in front and rear.
Constantine Registry Founding Member #0235 1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete. 1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car. https://www.youtube.com/watch?v=z8y4cwcvK0s 1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car. 1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything. |
#4 | |
Thanks.
[SIGPIC][/SIGPIC] |
