Old 06-15-2019   #1
TexasZR1
Default Secondaries not functioning
My secondaries started acting up with the heat lately.
They work fine when cold, then after warm-up (anywhere from 5 miles to 20 miles) they stop functioning.
I first replaced the fuel pumps (they were original). Fuel pressure test shows ~40psi at idle and ~50 at WOT.
Injectors were replaced by the prior owner.
The vacuum pump is functioning properly (runs for about 10 seconds to build vacuum; cycles for about 1 second every 3 or 4 minutes).
When jumping the pink wire at the ecm to ground, i get intermittent function of the secondary butterflys when warm. When it's cool, everything works great.
I'm thinking it's the vacuum solenoid?
Wiring diagram shows only one vacuum solenoid for the secondaries. Is this correct?
I need to start ordering other parts (gaskets, etc) to pull the plenum.
As a sanity check, any other diagnostic I should do first?
Also, anyone have a parts list for stuff to order for the plenum RR?
Do I need to remove the throttle body to pull the plenum?
Do I need anything other than Jerry's "36 pc Fuel Injector Maint"?
I've also seen recommendations to block some coolant ports?
TexasZR1 is offline   Reply With Quote
Old 06-15-2019   #2
Young1
Young1's Avatar
Default Re: Secondaries not functioning
Because my Z is not a DD I always disassemble first, test and assess, then order parts. Maybe you have mice or lizards living in there! It is well worth the money to get Marc Heibecks DVD for your first plenum pull. zr-1 specialist.com
Steve Young
Second Owner
SOLD
SOLD
Old 06-15-2019   #3
Ccmano
When hot?
Are you looking at both or just one?
Its possible
Yes Correct
You read this correct? http://www.zr1specialist.com/HAT%20W...%20Working.pdf
Just the plenum gaskets, replace the check valve while your in there it’s cheap and often causes problems.
No
injectors have already been replaced, no need to pull them again. Not part of the basic plenum pull process.
Stick to one issue at a time although it does make a plenum pull a snap.
See my comments in RED above. With an intermittent and heat related problem like this and with vacuum holding when hot I’m inclined to think it’s more of an electrical issue. The solenoid is the only related electrical item under the plenum. I’m sure others will chime in. Keep us posted.
H
Old 06-15-2019   #4
Certain DTC’s will disable the Secondary port throttles, i.e. full power. If that is the case, you should see a light in the panel, usually SERVICE Engine Soon.
I suggest you check stored codes, make note of them, then clear all. Drive the car again under the same conditions that have disabled full power until it happens again, then check stored codes again. You may have a bad/missing light in the panel. This procedure will at least eliminate the possibility without having to disassemble anything.
Old 06-16-2019   #5
TexasZR1
H
Thanks much for your help and guidance!
Vacuum system is functioning well when cold and hot.
I've looked at both actuators, however, when it doesn't function, neither do. When it DOES function, both move.
I did read that diagnostic and a few others. I tried pretty well all I can with the plenum on I think. Given that grounding the pink wire works only when cold, the issue is almost certainly under the plenum.
I have checked for codes and its all clear (12). The SES light does work, but it never illuminated when I'm having the issue.
Power wise, I'm certain they are not opening (flat above 4500rpm).
I will order a set of plenum gaskets, pick up some coolant, solenoid and check valve and see if I can get this sorted.
Thanks everyone for the input! Will report back soon.
Old 10-09-2019   #6
TexasZR1
I'm having a hard time locating a replacement vacuum solenoid.
Seems pn 1997222 is out of production and out of stock...
Did I read there is a near twin to this part with a different bracket that can be substituted?
Old 10-09-2019   #7
Young1
Young1's Avatar
https://www.rockauto.com/en/partsearch/?partnum=1997212
Type 1997212 into search of rock auto. This is what you need. Carefully change the bracket and cut a bit of plastic for the electric connector to fit. I did this myself about three years ago.
Steve Young
Second Owner
SOLD
SOLD
Old 10-09-2019   #8
TexasZR1
Thank you! Part ordered!
I found some other things to tighten and clean up while in there, so the plenum pull will have been well worth it.
Leaking pcv cover, lose injector housing bolts, will look more tomorrow.
Old 10-09-2019   #9
*Power wise, I'm certain they are not opening (flat above 4500rpm).
The stock "accordian" air hose between the air filter and the throttle body horn collapses under WOT and cuts off acceleration right at the 4500 +/- RPM you spoke of. It's a common issue with 26+ yr old plastic.
I fixed mine with a aluminum sleeve liner for that hose. Marc Haibeck sells some wire hoops to be inserted at intervals along the length of the hose, and Jerry's Gaskets sells a replacement hose which also adds to the esthetics.
Get back 2 us!
Old 10-09-2019   #10
Young1
Young1's Avatar
Zip tie every vacuum and pvc joint you can. I got small brass round stock at Lowe’s. Formed it around the air horn and popped it inside the pleats. I think I put in 3 pieces. Easy and cheap. Runs to the rev limiter quite often too. You are welcome!
Steve Young
Second Owner
SOLD
SOLD
