Old 05-07-2019   #1
Flyman 27
Flyman 27's Avatar
Default Start up knock
My '91 has always knocked a little upon startup. It fades away after a couple seconds. This year when I started it the knock was much louder & lasted much longer. Now it is doing the extra loud knock on all start ups.
I have had some experience with overhead cam engines and I would guess the problem to be cam chain slop. Either one or more chain guides are worn or broken.
Has anyone done this repair before? Any idea of cost?
Dan
[SIGPIC][/SIGPIC]
Cams by Pete
Old 05-07-2019   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Start up knock
Which oil filter do you use?
and, please explain, deep knock or a metallic rattle?
Marty
Old 05-07-2019   #3
rush91
My '91 has always had a second or so of rattle, but have noticed it goes away after an oil change. ( Amsoil and AC Delco PF970C ) Once I get around 1000 miles or so on the new oil change, the rattle slowly comes back.....
Old 05-07-2019   #4
DRM500RUBYZR-1
Try the Bosch 3401 listed below and please report back if this changes it.
Bosch 3401 Premium FILTECH Oil Filter
by Bosch Automotive
/* * Fix for UDP-1061. Average customer reviews has a small extra line on hover * https://omni-grok.amazon.com/xref/sr...teTemplates#40 */ .noUnderline a:hover { text-decoration: none; } 4.6 out of 5 stars 1,879 customer reviews
Price:$9.32 FREE One-Day
  • Exclusive FILTECH media technology screens out more harmful contaminants for greater engine protection
  • Strong steel base plates and housings prevent warpage, leaks, and poor fit
  • Silicone anti-drainback valve ensures a supply of clean oil when the vehicle is started
  • High lubricity gasket design provides a tight seal, yet allows for easy removal
See more product details
Old 05-07-2019   #5
Flyman 27
Flyman 27's Avatar
I use the WIX 51324, the HD filter with the silicone anti-drainback valve. They are supposed to be one of the highest rated filters for this engine.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 05-07-2019   #6
DRM500RUBYZR-1
OK,
Rattle or KNOCK?
Old 05-07-2019   #7
Flyman 27
Flyman 27's Avatar
Years ago I had a Lincoln with a 4.6L DOHC engine. It had a failed chain tensioner and the chain slapped against the housing upon startup.
What I am experiencing sounds like just like that.
I ordered the oil filter. It's worth a try.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 05-07-2019   #8
DRM500RUBYZR-1
OK, that does sound like tensioner/ chain noise.
Which oil are you using?
Old 05-07-2019   #9
DRM500RUBYZR-1
Change to the Bosch filter now that it is doing it again after 1000 miles.
Just change the filter and let us know what happens.
Marty
Old 05-07-2019   #10
Demps
Demps's Avatar
If isolated to chain rattle at start up and if still somewhat present after new anti-drainback oil filter...this helps some:
https://www.jerrysgaskets.com/housin...ign-90-95-1g4/
