#11 | |
I don’t have any issue w the Osram’s and Appradio4! |
#12 |
![]() Join Date: Jul 2007
Guess I am just lucky, I have had issues with reception in my car for whatever reason.. unfortunately I have to go back to the halogens for now
#13 | |
![]() Join Date: Nov 2007
No issue in IL. Local laws may vary. |
#14 |
#15 | |
H ![]() |
#16 |
I have a set of JDM Astar LED Fogs, no issues, other than the light pattern on them.
I can try Ferrite beads, Worth a shot, if not then back to Halogen. I did notice an odd pattern and a dark spot from the LEDs.. We will see how it works out
#17 | |
I wanted them to stay on w high beams. Did the same thing on my Xfire. |
#18 |
#19 |
It's funny... I just did an install of the Afeax LED headlamps and stumbled into this fog light issue. Didn't take long to figure out what was up, drew out a plan to do this "piggy back" relay and thought I wonder if someone on the registry has done this... the answer is always yes. This really is a fantastic archive for our cars.
Quick product review: the Afeax LED headlamp replaacement from Amazon (B07BWBRDJ5) $85.99 for the pair. The install was straightfoward. The bulb almost fits in the headlamp bucket, but does fit under the retaining ring, so if you are careful to keep it "eve" as you install it, it will go in straight and not interfere with anything. The bulb looks a little "gimmicky" but as night fell i really was quite impressed with the beam pattern. Here's a pic of the unit installed and the low beam pattern on the highway after a few rounds of trial and error adjustments: ![]() ![]() Ok... what did I do wrong here, these images are blowing up the thread Last edited by UnderPressure; 03-10-2020 at 01:29 AM. Reason: Added review and images |
#20 | |
A schematic...would be nice, Jeff! |
