Old 04-14-2019   #1
Default LED Headlight with fog light issue...
Yeah, I know it has been posted and gone over several times.
BUT
Now time to post my solution I used on my 1990
**Disclaimer: Findings based on my 1990 and FSM, other years may vary**
In the FSM the shows that the Fog light relay grounds through the High Beam. When the high beams are activated in the OEM solution, 12v is applied on both sides of the coil for the relay which then causes the lights to turn off.
When we switch to LED, the high beam filament is replace with electronics, so that does not work so well. Most use resistors, which to me, still gives the load of a Halogen/ Filament light, yes it works, but I want the efficiency benefit.
I acquired a socket and relay from a donor harness I have, I added the relay to my harness to accomplish what I need. Here are the details:
Find the Fog Lamp relay. in my 1990 it is the furthest to the right under the dash.. Look for the Light Green wire. that is the wire you need to manipulate..
Unpin the LT GRN from the current relay move it to 86 of the added relay.
Pin a new wire in the spot where you removed the LT GRN (it is either 85 or 86), Pin the other end of this wire to 87a of your added relay.
On the added relay, Pin 30 and Pin 85 are both connected to ground.
Done, no wires cut, not relays tampered with. I have not installed LED Headlights just yet, but got the car ready for them. So this should work without issue. works fine with my current lights. I will be adding LED Headlights and LED Fog Lights soon.
Old 04-14-2019   #2
Ccmano
Default Re: LED Headlight with fog light issue...
Nice, mine will be in process tomorrow. Sounds like the most elegant solution yet.
H
Old 04-15-2019   #3
I used a variation of Yun’s solution by cutting the relay leg connected to the lt grn wire and then soldering a wire to that cut down leg running it to a ground using as stud found halfway up alongside the door opening. The stud will be easier to see if u remove the side bezel for the fuse panel.
Old 04-15-2019   #4
Ccmano
Relay location is Driver side or passenger side?
H
Old 04-15-2019   #5
Passenger side
Old 04-15-2019   #6
FSM shows location incorrectly. Of the 4 relays there, its the one closest to the passenger door opening.
Old 04-28-2019   #7
to update.. the Mod I made works as expected (like factory) with LED Headlights and LED Fog Lights
Old 04-28-2019   #8
Ccmano
Agreed... mine too.
H
Old 05-06-2019   #9
ghlkal
ghlkal's Avatar
Nice, thanks for posting this.
Bookmarked for when I get LED headlights ...
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 05-06-2019   #10
Want a set of LED headlights? PM Me. I have a set with maybe an hour of time on them. I need to remove them as they cause static on the FM of my Aftermarket Radio.. I also have the JDM Astar rear LED bulbs (caused the same issue for me)
I will be going back to my Halogens
