Old 03-13-2019   #11
kr1276
Default Re: Fuel Sending Unit
Yes. Check out the link below and you will see pics of the end result. This is not mine but I am doing mine just like this.
http://www.zr1.net/forum/showthread.php?t=29705
kr1276 is offline   Reply With Quote
Old 03-13-2019   #12
Ccmano
I see. So your just removing the rheostat and float from the SW frame and attaching it in place of the OEM rheostat.
H
Old 03-13-2019   #13
Jagdpanzer
Jagdpanzer's Avatar
I found the existing mount area to flimsy so I reinforced with the SW mount bracket
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-13-2019   #14
kr1276
I am also using the SW mount as Phil mentioned. Thanks again Phil for the pics! Should last a lifetime this way
Old 04-02-2019   #15
W i l l
A big thank you to the gentleman from Washington who sold me a used sending unit for the ZR-1. I put high flow Walbro pumps in it and it goes back in the car on Thursday. Then off to the South Texas ZR-1 BBQ on Friday!!! You gotta love this spring weather :-)
W i l l is offline   Reply With Quote
Old 04-02-2019   #16
Pete
Pete's Avatar
If secondary port throttles are removed we can use a regular single pump C4 sending unit with better pump.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-02-2019   #17
Ccmano
Pete
Now that’s interesting, tell me more... what size pump and does the programming need to be changed.
H
Old 04-02-2019   #18
Pete
Pete's Avatar
H
You will need to use a couple of clamps to mount the pump to the sending unit.
It could be done and with this pump http://walbrofuelpumps.com/450lph-wa...f90000267.html should be plenty to hadle anything.
I'm thinking of going that route.
Yes, i would reprogram the chip for no secondaries.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-02-2019   #19
Ccmano
Pete
Cool, already lost my secondaries and tuned appropriately. Have to look into that.
H
Old 04-02-2019   #20
indy91zr1
Pete
I ran this pump in my Subaru STI. I had to hardwire it to get the best performance out of it. That was just because of the fuel controller they used for the stock pump though. I don't know if the z has that or not? It did exactly what is was supposed to do though. Was a great pump.
indy91zr1 is offline   Reply With Quote
