Old 01-09-2008   #1
kenthompson
kenthompson's Avatar
Default Re: PCV Valves
Originally Posted by kdmranch
I noticed that the PCV valve mounting hose was all punky on the 90.
Is "pucky" a technical term that I need to learn to work on my car?
Seriously, they say the valves have different springs in them so that they open up at different times. When I rebuilt mine, I just used the same valve on both.
kenthompson is offline   Reply With Quote
Old 01-10-2008   #2
bradslt5
there are definatly 2 different pvc valves . youd have to ask jeff if they really makes a difference on if you can use others also there is an order that they are placed
Old 01-10-2008   #3
kdmranch
The term is "punky", not "pucky". I think that is a highly technical term, {as you had noted} that I am very sure I am not qualified to use.
kdmranch is offline   Reply With Quote
Old 01-11-2008   #4
kenthompson
Oh yea, that's right. Pucky is what my DAD used to call a tube of silicone. Highly technical term
Old 01-11-2008   #5
Bob G
What is the better set up for the strip ? thanks Bob
Bob G is offline   Reply With Quote
Old 01-11-2008   #6
petefias
Strip, as in removing clothes?
petefias is offline   Reply With Quote
Old 01-11-2008   #7
bradslt5
could one use breathers instaed of having the system closed . if the car was going to be used as a drag car only
Old 01-11-2008   #8
flyin ryan
flyin ryan's Avatar
your better off keeping it closed & at least try to keep some negative pressure (vacuum) in the crankcase. you won't have any manifold vac. at W.O.T. of coarse, well next to none, but you will in the staging lanes & after your burn-out. will an open system (breathers) you'll never have any crank. vac. at any time. the whole idea is to keep the cylinder walls clean, the rings stable & keep the oil away from the rotator (crank, rods). with breathers you may not build up any pressure but you'll never build any crank vacuum either & that's the goal. on the better stuff i do, 2 H.P. per cube & up, i generally turn the rear main seal around, backwards, because i'm trying to run so much crankcase vac. it will flatten out the seal & pull in fresh air. this way the more water depression, vacuum, it will tighten up on the crank. that how important vacuum is to me. it's kinda a tough deal with the LT-5 having so little volume but venting into the atmosphere is not the answer if a guys looking for power, IMO.
