![]() Join Date: Jan 2015
It seems I have a significant oil leak at the oil pressure switch (for the dash light), on my 91. It's located at the bottom of the oil filter housing. I'm having a hard time determining how to remove and replace it. Do I need to remove the entire oil filter housing, or can I remove the oil cooler lines and access it from the front. Any help would be much appreciated.
Thanks for the quick reply. I guess I should have used the search option first. Apparently not the first one to leak. Thanks again!
#4 | |
H ![]() |
Thank you Dynomite you beat me to it
![]() Dave |
