Old 11-13-2018   #1
Bob Eyres
Default A/C Compressor replacement
We’re trying to change out the original compressor on my 91” with a new one. I got a 93” unit (new) from Rockauto. That’s set up for 134, But the old manifold that bolts to it will not seal because of a different O ring configuration.
Does anyone know where I can get a new manifold/ hose Assy. that will mate the 93’ compressor with my 91’?
Or some other solution?
TIA
"It's about the car, not the people."
1991 ZR-1 White/Black #1236 (Owner since 1994).
Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft.
Old 11-14-2018   #2
jss06c6
Default Re: A/C Compressor replacement
Bob,
Do you have your '91 compressor still? I moved the '91 "manifold" to the newer 134 compressor without issue. Can you do this?
Steve
Old 11-14-2018   #3
jss06c6
I may not be understanding the problem.. Do you have any pics? I just did this and moved my '91 manifold to my 134 compressor..
Old 11-14-2018   #4
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Hi I have a 1990 that do you have to do when changing from R12 to R134A
Thanks Glen
Sent from my SM-G960F using ZR-1 Net Registry mobile app
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 11-20-2018   #5
Bob Eyres
Sorry for the delay in responding.
We managed to mate the new compressor, a Delco unit from Jerry, and it’s installed.
But a new problem cropped up. After the new serpentine belt was installed and the engine fired up there was a mismatch between the compressor pulley and the belt location. Once you revved the motor, it engaged the compressor clutch, the rear edge of the belt started to rub on the pulley. It ate about 3/16” off the edge of the belt. Misalignment sure, but why? It’s a new Denso r134 compressor, in place of the old r12 unit, with a new clutch from Rockauto.
Anyone else have this problem?
Old 11-20-2018   #6
jss06c6
??, I took the clutch and pulley off of my R-12 compressor and put it on my R-134 compressor.. belt runs true..
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 11-20-2018   #7
Bob,
It’s not uncommon for ZR-1, LT5 (VIN J)specific parts to be listed incorrectly as sharing fitment with base engines (VIN Y). What you have is a clutch for a base engine(VIN Y). They look the same but the offset is not right for the LT5.
The problem you have is not new & has been experienced many times before.
Old 11-20-2018   #8
Yes, the alignment issue is in the hub of the clutch, not the compressor.
Old 11-21-2018   #9
Bob Eyres
That’s what I was suspecting. Thanks guys I’ll be on the phone to Rockauto today
