11-13-2018 | #1 |
Scanner
Any recommendations for an OBD1 scanner for our cars?
Thanks! Sent from my iPad using ZR-1 Net Registry |
11-13-2018 | #2 |
Re: Scanner
What functionality do you want?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
11-14-2018 | #3 |
Re: Scanner
Sorry for the slow reply Jeff. I am looking for a scanner that identifies Codes.
Thanks, Jim |
11-14-2018 | #4 |
Re: Scanner
just codes? then anything OBD1 should be fine.. If you are an Android user, then I suggest a simple cable and ALDLDroid..
11-14-2018 | #5 |
Re: Scanner
I would suggest an Autoxray reader/scanner because you can use it on other cars.
However if you find one, a Tech 1A can perform a multitude of tests that a regular reader scanner cant. Also GM used a Tech 1A back in the day GC
11-14-2018 | #6 |
Re: Scanner
If u simply want to identify codes, u can use a paper clip. Then the codes are in the FSM or here on the forum.
