Old 11-11-2018   #1
zr1assassin
Default Accel 24# injectors work?
I got a Smokin deal on a set of (8) 24# Accel fuel injectors, will these work as secondaries on a stock engine without retuning? Plug n play like the 21#s?
zr1assassin is offline   Reply With Quote
Old 11-11-2018   #2
zr1assassin
Default Re: Accel 24# injectors work?
Anyone.....
Old 11-11-2018   #3
No they will run way too rich...
Old 11-11-2018   #4
zr1assassin
But will work with proper tuning?
Old 11-11-2018   #5
Karl
Karl's Avatar
Yes.
I run the same injectors on my primary & secondaries.
Old 11-11-2018   #6
zr1assassin
Originally Posted by Karl View Post
Yes.
Stock engine or bigger ci?
Old 11-11-2018   #7
You will likely get a rich code.
Old 11-11-2018   #8
The calibration needs to be modified to tell the ECM it has bigger injectors. That might be enough but likely it won’t be. U will at least need to run a before and after datalog to confirm. The Injector Bias will also need to be updated to the correct values. Otherwise who knows.
Finally, I’m not a proponent of mixed injectors. Use one or the other. The calibration doesn’t differentiate between 2 different value injectors. Its looking for one type injector, and will treat the other one as if....
Old 11-11-2018   #9
zr1assassin
Well I know pete runs 24# for secondaries on his 391pkg. So you can mix/match, just didn't know if it was acceptable on a stock ci engine
Old 11-11-2018   #10
I love Pete. He is a great, great friend. Doesn’t mean I agree w everything he does. And he and I have discussed this. You can “make it work” but I’d rather not.
