#11 | |
![]() Join Date: Feb 2006
I haven't myself ever worked on a fuel sender, so I am learning. |
#12 |
![]() Join Date: Apr 2017
I was told by a very reliable source (-=Jef=-) that the sender unit is the same as a standard C4. So you could find a deal on a standard C4 complete unit & swap the sending unit. That would be the least expensive way to get a new sending unit.
[SIGPIC][/SIGPIC] 91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
#13 |
![]() Join Date: Aug 2015
I've not heard of a "bladder" in the fuel tank, but here is a tray that lies directly below the sending unit arm and float. There is a chance that your float arm somehow got bent to the side slightly during installation. This would cause the float to hang up on the lip of the float tray. I would expect, however, that this would cause you to show fuel still in the tank, when in reality, the tank is nearly empty.[ATTACH]
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#14 |
![]() Join Date: Nov 2007
#15 |
Thanks for the replies. And this is good to know. I believe this because it is the same tank as other C4's. It is just the piggy backing hardware and extra pump, which I already have.
#16 | |
Depending on condition, I wonder if there would be benefits of a new sock and pumps on a 60k+ mile car that has had another 100 HP added to it with Marc's 510/350 package. |
#17 |
![]() Join Date: May 2007
I have been cleaning the fuel level sensor as a repair procedure for quite a while. Recently I have encountered two units that would not stop skipping resistance at less than 20 ohms. That's about 3 to 0 bars on the gauge. This can cause the nasty jump from 3 to 0 bars in just a few miles.
I'm using a Stewart Warner universal fit sensor and fabricating an attachment to ZR-1 sender assembly. It's a modern thick film design. I get them from Summit Racing. Number SWW-439363-D. $37. |
#18 |
![]() Join Date: Jun 2004
This is also a good time to think about changing out the plastic “y” for the billet replacement unit I machine. It will not break nor leak like the discontinued plastic one will. If interested contact me via email. Thanks for looking.
#19 |
![]() Join Date: Jul 2016
Marc, thanks for your post and finding a solution. Also, Jssc06c6 is almost certainly describing the cause of my old car’s behavior. The myth of the tank bladder: busted.
#20 |
Thank you Marc for sharing this information. I was also thinking about going the same route. Looks like a reasonable cost solution that solves another parts availability problem. Time to dig out that spare ZR-1 gas tank pump/sending unit assembly I’ve been holding on to for years with a defective level sensor.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 09-22-2018 at 12:17 PM. |
