09-09-2018 | #1 |
Console & Center Dash Service?
One thing always leads to another!
Pulled the drivers seat to repair bladder pump & replace bladder. (Passenger side done last week). While it is out I decided to go ahead and remove the radio control head as the CD deck is inop. Sending it to Dr. Don. He did the DCM and all 4 speaker assemblys a few weeks ago. (Not real sure why I am spending all this money on the radio. I turn it off everytime I go for a drive!) My question is: What other service should I do while I have the console & center dash apart? I intend to clean the AC control button contacts and also the power key switch contacts as I have seen these can give trouble. Of course, I will clean the whole area before re-assembly. Is there anything else I should address while I am in this far? Everybody likes pics. Here's a couple. z090918-1.jpg z090918-2.jpg
Kenny 1990 #442 |
09-09-2018 | #2 |
Re: Console & Center Dash Service?
I'm interested in what you used to repair (replace I assume) the seat bladder .. a direct replacement part, or a similar substitute? Something I need to do as well. Already repaired the pump diaphragms.
Sent from my moto g(6) play using ZR-1 Net Registry mobile app
-Stephen 1990 #2288 |
09-09-2018 | #3 | |
I saw several threads about modifying something to use as bladders. Blood pressure cuffs, bicycle tubes, etc. I didn't think the cost of replacement bladders was enough to re-invent the wheel. I got mine from Davie's. (corvetteparts.com). Their part # is 421024. Nearly everyone has them. Run 70-100 bucks each depending on who has them on sale. Be sure and check the female hose connectors. Mine were rotten and fell apart when I unhooked them. Davie's part # 421041. Supposedly you can just release the bottom and 1 side of the cover to install the bladder. I went ahead and opened up the whole bottom section to be sure and get all the old out and have the new one laying correctly. Not too bad a job. Good luck!
Kenny 1990 #442 |
09-09-2018 | #4 |
Thanks Kenny. I kind of had the same feeling when researching things originally .. seemed a lot of trouble to re-engineer bladders for marginal savings .. best to go ahead and get the direct replacements. Thanks for the part refs!
09-09-2018 | #5 |
To contribute to the topic of the thread - there were two additional things (besides sending the head unit off for repair like you did) I had to do under the console. First was to refurbish the power key tumbler; it was not closing the circuit reliably. Second was to reinsert the INFL REST light bulb that had been removed at some point, which eventually led to me having to re-seat the air bag sensors and clear the code properly.
So maybe make sure all of the DIC lights are installed that should be?
09-09-2018 | #6 |
Checking all the bulbs is a good idea.
Thanks for the suggestion.
Kenny 1990 #442 |
