![]() Join Date: Dec 2003
Due to lack of availability for OEM original parts, primarily rings, pistons, sleeves & connecting rods (in that order), Jerrys Gaskets has developed a package containing the same components...... only better. The package is as close to being drop-in, as close as we can make it, like the original parts. Additional steps required for installation are final honing of cylinder sleeves to finish size/clearance and re-balancing.
The new package is applicable for a stock rebuild AND/OR a performance enhancement rebuild. Displacement has been increased to a 4.000" bore for 368 cubic inches. All components are match designed. As an added bonus, Jerrys Gaskets will end gap the new piston rings to the proper dimension, with our new Total Seal Precision Power Ring Filer. For the do-it yourself owner, we have been expanding our LT5 Special Tools inventory. Although the tools are available for purchase, the intended purpose is to make them available for rental on a much lower cost basis. Each rental period is for 30 days, round trip from us to you. Simply organize your schedule & order when you are ready. Availability may be limited by inventory & prior purchase/rental. http://www.jerrysgaskets.com/368-sle...new-90-95-000/ ![]()
#2 | |
Sent from my SM-G955U using ZR-1 Net Registry mobile app |
![]() Join Date: Jul 2016
Thanks for developing this kit.
![]() Join Date: Jul 2004
Jerry are there any tools youre missing?
I have quite a few if you need to make copies.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
Jerry, Do you have rod and main bearings too?
Ultimately if I don’t sell my long block I may rebuild this way. H ![]() |
#6 | |
Hi Johnny, Thanks for the offer. I may need to take you up on it. Sent from my iPhone using ZR-1 Net Registry
#7 | |
Yes, we have rod & main bearings. http://www.jerrysgaskets.com/bearing...rod-90-95-1b1/ http://www.jerrysgaskets.com/bearing...n-90-95-17a-e/
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 08-11-2018 at 08:27 PM. |
