Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 07-31-2018   #31
Norwegianmopar
Norwegianmopar's Avatar
Default Re: 91 ZR-1 #400 ready for the roadtrip
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 07-31-2018   #32
Norwegianmopar
Originally Posted by Norwegianmopar View Post
Outside our relatives' home in Karlstad, Sweden.Attachment 7933
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-04-2018   #33
conesare2seconds
Were you able to get her back on the road?
Old 08-05-2018   #34
Norwegianmopar
She runs ok, but not as she should. Have an appointment at a local garage that specializes on american cars, and is an licensed Corvette service shop, to get it checked out. Can be plugs or wires, vacuum, cats...many suggestions. Bet I will be screaming in the left lane soon [emoji106]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-06-2018   #35
Norwegianmopar
Today, after standing still for two days, she ran like she used to do..! I have no clue why, but the rattle can sound was not there and she danced on will when I asked her to [emoji56]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-07-2018   #36
Norwegianmopar
Suspect it could be a loose connector or ground wire somewhere...will take a closer look when we get home.
Tomorrow we will hit the road again, this time to visit a fellow ZR-1 owner in Norway before heading home.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-07-2018   #37
S.hafsmo
S.hafsmo's Avatar
A red one?
- '90 ZR-1
Old 08-07-2018   #38
Norwegianmopar
Black on black 91.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-08-2018   #39
Norwegianmopar
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-08-2018   #40
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Just a thought.
Check your drain and boot around the gas filler area.
I recall seeing you washed the car with a pressure washer a day or so before you had the performance anomaly. Perhaps the drain might be clogged, filling the boot and some water entered the tank.
Alternatively, perhaps you picked up some contaminated fuel.
Strange that the problem appeared then vanished.
This leads me to suspect a fuel issue as opposed to a mechanical one.
Mechanical issues typically don't come and go.
Glad you are making it back home!
Marty
