Old 05-19-2018   #1
TX '90 ZR1
TX '90 ZR1's Avatar
Default Fuel Pump "Y" Connector
Anybody know where to get the "Y" that connects the fuel pump lines to the outlet?
Discovered mine has a small crack in it and is losing pressure.
It is the one connecting the 3 hoses together on the sending unit assy. Believe it is 5/16" on the pump sides and 3/8" on the outlet side.
Also, what hose does everybody use to replace the original on the sending unit?
Thanks for the help.
Kenny
1990 #442
Old 05-19-2018   #2
jss06c6
Default Re: Fuel Pump "Y" Connector
Pictures would help.. this "Y"?[ATTACH]
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 05-19-2018   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Yes, that is it. Here's a pic. It is the "Y" shaped piece in center of photo.z051918-01.jpg
Kenny
1990 #442
Old 05-25-2018   #4
phrogs
phrogs's Avatar
You would need to salvage that off another pump assembly.
Or spend $200 plus dollars for a whole new assembly.
I have a couple of these let me check that piece and see if Its usable.
Btw what you think its worth?
JOHNNY P
Currently own
Old 05-25-2018   #5
spork2367
This would be an option:
https://www.usplastic.com/catalog/it...SABEgLcJPD_BwE
You just might need a different clamp to tighten the 3/8 hose onto the 5/16 barb. I looked into this awhile back.
Old 05-25-2018   #6
TX '90 ZR1
TX '90 ZR1's Avatar
Johnny,
Thanks for the offer.
I am concerned that an original plastic one would probably be brittle just like mine is. Nearly 30 years is a long time for plastic to remain serviceable.
I was able to do a repair on mine and everything is holding fine for now, but I am checking into several options for a better permanent replacement.
The 2 different size hoses sort of throws a kink into buying one off the shelf.
I'll report back if I come up with something.
Kenny
1990 #442
Old 05-25-2018   #7
TX '90 ZR1
TX '90 ZR1's Avatar
Yes, I saw those. The configuration is a little different, but it might work. I may get one and try it. Depending on the diameter of the barb on the side for the 3/8" hose, might be able to get it to seal properly.
They have one for 3/8" also, but I am pretty sure 3/8" hose will not hold securely on the pump outlets.
Thanks for the reply.
Kenny
1990 #442
Old 05-26-2018   #8
Andy
There might be something useful in this thread http://www.zr1.net/forum/showthread....t=fuel+fitting
If you haven't already seen it.
1990 black on black #1042 - sadly - sold
1993 Ruby #140 - stock
1991 QB #1608 - heads and top end ported, Watson headers, B&B 3"exhaust, Haibeck chip, 4.10 gears
Andy is offline   Reply With Quote
