Old 03-29-2018   #1
Default Re: C6Zo6 wheel fittment
Spacers(18mm hub and wheel centric) for the rears and longer wheel studs.
Fronts work best if used w Z06 brake rotors, otherwise the front tire will extend about 5 mm beyond the wheel opening. But you can use the stock rotors and calipers. I have the Z06 6 piston in front and the 4 piston in back. The 19s in back make the stock rotors and calipers look puny.
Old 03-30-2018   #2
BecauseEYEgotta
The Z06 brakes are one of the upgrades I’m seriously considering doing once I get one. Thanks for the input [emoji106]
BecauseEYEgotta is offline   Reply With Quote
Old 03-30-2018   #3
I love the Z06 brakes. They look awesome but the work even better. You literally “stop at will”. I hardly ever use any brake pressure because they just STOP u. In most cases, sooner than u r expecting.
And rather than paint my calipers, I had them polished.
Old 03-30-2018   #4
BecauseEYEgotta
Yeah, it’s a great combo of looks and performance!
My 1st C6 was a GS rather than a base. I drove both and was stunned how great the bigger brakes worked.
Old 03-30-2018   #5
BTW, I also invested in 2 piece rotors F/R. Took 36lbs of unsprung rotating mass off. Not cheap but the steering feels much more direct and requires less effort w more feel.
Old 04-01-2018   #6
RICKYRJ1
RICKYRJ1's Avatar
I used a quality wheel adapter instead of spacer and longer studs. Works perfect
