Old 03-17-2018   #1
Reichert
Default Initial maintenance finally finished!
Hi!
As soon as I took delivery of my ‘90 ZR-1, it was obvious there was a slight engine miss after the car was warmed up, which led me down the rabbit hole of learning all about the ethanol intolerance problem in the 1990 model year OEM injectors. So up on jack stands she went for an injector swap and a bunch of other “baseline” preventative maintenance to ensure I start off on the right foot. Here’s the after action report, for posterity.
Mechanical:
  • Fuel injectors: New stainless set from FIC.
  • Spark plug wires: I have the original “Corvette LT-5” wires which are probably fine, but I took them off and stashed them away in favor of a NOS delco (red) set.
  • Oxygen sensors: Replaced both with delco units. Passenger side connector was a PITA.
  • Secondary vacuum solenoid: Identified a vacuum leak in the secondary system, and isolated it to the solenoid. Couldn’t find NOS of correct part #1997222, so I bought #1997212 from Johnny5. Had to modify the connector and swap out the mounting bracket with the old one, but otherwise worked perfectly.
  • Thermostat: Bought the wrong one at Autozone and then did a lot of research and found that Jerry is the only one that keeps a reliable stock of the correct part, as far as I can tell.
  • Tires: Tires on the car were 2001 Goodyear F1's .. obviously had to go! Replaced with Nitto NT555 G2, which was the only matching front/rear set I could find.
Changed fluids:
Engine oil (AMSOIL AMO 10W-40), clutch (Dot-3 synthetic brake fluid - just replaced what was in the reservoir), coolant (Zerex “green”), brake (Dot-3 synthetic), transmission (Castrol Edge 10W-60 Synthetic), differential (Mobil 1 75W-90).
Everything here was pretty straight forward. The one exception is refilling coolant: This Haibeck article about filling the cooling system is super important! Thankfully I didn't have any airlock issues.
Electrical:
  • Fog light bulbs: Bought two, replaced just one that was out.
  • Stereo system components: Everything was fried, so I sent the amps, tuner, and head unit to Factory Stereo repair for a refurb. Pricey but sounds like new now - the Bose system is loud!
  • Power key: The “Full Power” light was flickering when I jiggled the key, so I took the lock cylinder apart and cleaned all of the contacts.
Resources that helped:
Cost: About $2700 overall. The majority of that was the injectors, new tires, and the stereo system repair which was the only labor cost I paid. Fluids and small stuff was less than $500.
Todo: Power steering fluid, and a couple of electrical issues in the cabin - seat belt light is stuck on, and the seat recliners are barely working. Of course the lumbar bladders are toast. Probably need to pull the seats out and refresh everything.
I only have 2 screws leftover. I'm sure it's fine.
Reichert is offline   Reply With Quote
Old 03-17-2018   #2
Ccmano
Ccmano's Avatar
Default Re: Initial maintenance finally finished!
Congrats! You have now been fully initiated...
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-17-2018   #3
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Well done!
We have done the same on many ZR-1's.
Once done; Good for another 25 years!
Now go out, jump on it, and experience what we all call "Perma Grin"!
One suggestion.
Take some time to remove and evaluate the fuel pump/sender assembly.
Also, peer down in to the fuel tank.
The metal structure that the pumps and sender are mounted upon is VERY prone to rust out, leaving much scale and flakes in the tank.
Not something you want to draw into those new injectors.
Take a moment and replace the fuel filter as well.
Again; well done!
Marty
