Old 02-11-2018   #1
tpepmeie
Default Winter build Stock CID project
Here's some eye candy from the new project. Stock pistons, machined for valve reliefs. This will make room for a fairly aggressive cam lift. Wonder what's possible from 350cid???
Old 02-11-2018   #2
efnfast
Default Re: Winter build Stock CID project
Do we know what the current hp leader is for 350 CID LT5?
Old 02-11-2018   #3
tpepmeie
Not really. I don’t believe anyone has tested one on an actual engine dynamometer. I plan to test this one.
Old 02-11-2018   #4
efnfast
I'm currently 451 at the wheels and didn't think there was much left without adding cubes. Maybe a little more with more aggresive cams. Which of course is exactly what you are looking for.
Old 02-11-2018   #5
Billy Mild
Problem with really aggressive cams, that if it requires piston mods you have to teardown the motor anyway.
You should be able to squeeze almost 100hp/liter with a tricked out engine.
Old 02-11-2018   #6
efnfast
At 15% loss, I calculate to 530. That's 93 per liter. I'm not sure I'd want more cams and still have to drive it on the street.
Old 02-11-2018   #7
jss06c6
Watching with interest!!
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 02-12-2018   #8
Pete said at one point in his motor's development that he was putting 474 HP to the wheels. Since then he has tweaked it a little more, he said.
Using the same math, that would tickle 557+ @ the crank, and his 11.04 at 129+ in the quarter, and IIRC* ~156 mph(?) in the half mile.
I don't know whether Pete has "eyebrow" cut his pistons or not. But, his 350 put on quite a show at many events, including BG!
One of his runs at Byron before the last mods.
https://www.youtube.com/watch?v=SFNFOhGGlR4
He says he keeps the secret in a Mason jar buried in the back yard.
Old 02-12-2018   #9
I believe Pete’s numbers use SAE correction.
Todd,
Are u thinking larger valves as well? Increase lift on Intake or Exhaust or both?
Old 02-12-2018   #10
But those videos are from Union Grove
