Old 01-24-2018   #11
Default Re: No power to fuel pump, wiring help needed.
The added time is to synchronize the timing of the injectors.. That is normal
Old 01-24-2018   #12
Demps
Demps's Avatar
Cut to the chase and replace the injectors too when you change filter.
Ted
An option that's served me well: Accel 150821 x2
Go to Autozone.com, add two to cart & select ship to home, input current discount code (SEE20 on 24 Jan 18). Shipped to your house <$510.
Go to jerrysgaskets.com & get plenum gaskets.
In your case, I'd look in starter valley for another rodent brothel. Be prepared to check all things for rat-snacking. Also, check vacuum condition.
Old 01-24-2018   #13
Ted
Good info on Auto Zone/injectors.
"RAT snacking"......loved that!
Old 01-24-2018   #14
Ccmano
I believe oil pressure must reach a certain level as well. But, yes all very normal.
If injectors are original I agree, replace them now.
H
Old 01-24-2018   #15
nherbst454
Ted
I just checked the 150821 on auozone and it claims that the won't fit my car, is this correct or is the website confused. I have the car selected as a 1990 ZR-1 for reference.
Thanks for all the help so far!
nherbst454 is offline   Reply With Quote
Old 01-24-2018   #16
Ccmano
Ignore the website, it is the correct injector. Here’s the best instructions from Marc Haibecks site....
http://www.zr1specialist.com/HAT%20W...eplacement.pdf
Good thread that describes the whole process.
http://zr1.net/forum/showthread.php?t=18722
H
