Old 11-15-2017   #1
2ljd
Default Brand new ZF trans
https://honolulu.craigslist.org/big/...386997277.html
In case anyone is interested...
2ljd is offline   Reply With Quote
Old 11-15-2017   #2
jmglyder
jmglyder's Avatar
Default Re: Brand new ZF trans
Hello,
According to the link:
Fitment Details: This transmission is a direct replacement for 1989-1996 Corvettes (excluding ZR-1).
I don't know enough about these to say one way or another but the seller says the ZR-1 is excluded.
John Glyder
ZR-1 Net Registry
Membership Chair
jmglyder is offline   Reply With Quote
Old 11-15-2017   #3
2ljd
I'm definitely no expert on these, but I thought there were a few mods that could be done and the trans would work in a Z?
Old 11-15-2017   #4
jmglyder
jmglyder's Avatar
I would hope that would be the case and if so someone will have a brand new trans
John Glyder
ZR-1 Net Registry
Membership Chair
Old 11-15-2017   #5
QB93Z
QB93Z's Avatar
There are two issues to understand about the ZF transmission in C4's.
1. The Non-ZR-1 transmission has a shorter input shaft and housing. The input shaft and housing from a donor ZR-1 version can be installed to make the transmission fit in a ZR-1.
2. The later model ZF transmissions have a small diameter input shaft housing and the Throw-out Bearing has internal nylon strips that slide on the input housing. To use the later model transmission on a early model ZR-1, the correct throw-out bearing must be installed. I think that the change occurred in 1994 but you should verify the fit of the throw out bearing on the housing before installing the clutch. I learned this the hard way during a clutch swap job when the transmission could not be installed.
Old 11-15-2017   #6
2ljd
Cool, thanks Jim!
Old 11-15-2017   #7
A few more details of the use of a Black Label Transmission in a Later Model ZR-1 (1995 for example)
Blue Label Removed (TOP), Rebuilt (ZFdoc) Black Label Installed (BOTTOM).
Rebuilt Black Label Transmission Installed
Old 11-15-2017   #8
Ccmano
It’s a last version Blue label 1052 000 089 for LT1/LT4.
Here’s another new one closer to home but also an LT1/LT4 version.
https://sfbay.craigslist.org/nby/pts...347609352.html
For the money, to buy one and convert the input shaft, I might as well just send mine to Bill B and have him rebuild it.
H
Old 11-15-2017   #9
H
Your last option is a winner as Bill B like Marc Haibeck are Rock Solid Professionals and perfectionists in what they do
Old 11-17-2017   #10
No argument here Cliff
