Old 11-09-2017   #1
Bob Eyres
Default Re: Brighter dash lights
The display on my 91' looks faded out and weak, hard to read. Is that what
You're talking about?
Does replacing the sensor give greater contrast? Or do you have to replace the whole DIC? (Dash Instrument Cluster?)
What's the best source for this? Price?
Thanks.
Old 11-09-2017   #2
Thanks.
www.batee.com..
you are going to need a new LCD polarizing film if your display is faded
Old 11-09-2017   #3
WVZR-1
OP - if the LCD seems presentable/acceptable with no sunglasses then quite likely your issue is with the "polarization" of your sunglasses. You could maybe spend much money on the cluster improvements and if your glasses are polarized your very likely to still have issues.
FLORIDA hints maybe "polarized" eye wear!
Old 11-09-2017   #4
In the mean time, if you switch on your fog lights, the DIC brightens and becomes visible, even w/ sun glasses - at least true for my non-polarized "sunnies".
Old 11-09-2017   #5
Ccmano
There are three major known issues with the 90+ C4 instrument pod.
1. Poor day time illumination. This is a lighting issue caused by the failure of the photo cell as discussed above.
2. Fading of the central lcd display. This is caused by failure of the lcd display itself and can result in the display characters virtually disappearing. This is the issue the second OP likely has.
3. Incorrect tach readings. Sometimes the tach needle will peg itself to the top or bottom of the display but generally just a noticeably inaccurate tach. Caused by failure of the control chip for the tach.
As noted polarized sunglasses can have an affect similar to #1 and 2. However that is easily eliminated by simply elvaluating the display without wearing them.
These items can all be resolved by the company Paul noted above. They can either do the work for you or sell you the parts to do it yourself.
H
Old 11-09-2017   #6
H
Hans great summury. OP which of these issues is your problem? GC
Old 11-10-2017   #7
davekp
My issue is with daytime brightness. It is not a polarized sunglasses issue. Have sent for replacement photocell- I'll report back when it is installed.
davekp is offline   Reply With Quote
Old 11-09-2017   #8
www.batee.com..
Yep that's where I sent mine as well,
