Old 10-28-2017   #1
Ozruss90
Ozruss90's Avatar
Default Under hood lamps
What do you guys do at a car show when you have the hood up. I believe the lamps come on via a mercury switch. Is there any way to turn them off, apart from wiring a switch in somewhere. Same with the interior lamps behind the seats, they come on when the rear hatch is up. Sorry for my ignorance but I’m a newbie to the c4 zr1 scene.
1990 #1948. 10k
Ozruss90 is offline   Reply With Quote
Old 10-28-2017   #2
BigJohn
BigJohn's Avatar
Default Re: Under hood lamps
Under hood unplug connector wires to light!
I never leave back hatch open!
BigJohn is online now   Reply With Quote
Old 10-28-2017   #3
mcich7781
mcich7781's Avatar
Install LED bulbs. I have had my hood open for 12 + hours. Very little amp draw.
Sent from my XT1254 using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 10-28-2017   #4
Pull the fuse down by the left cornering lamp. As for the rear hatch I have an extra latch I got from a junk yard from a broken rear glass.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-28-2017   #5
efnfast
I leave mine unplugged.
There are inline switches available.
Use LED's.
Old 10-28-2017   #6
Racinfan83
I switched to LED bulbs. I also bought a switch from Mid America...
http://www.mamotorworks.com/Corvette...rness-601721-1
Old 10-28-2017   #7
Re the hatch: if you have one of those hatch window props (holds the hatch open about an inch while driving) I wonder if just sticking it in the latch wouldn't work?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-28-2017   #8
I pulled the fuse years ago.
Old 10-28-2017   #9
You need the all in one piece and I am not sure it will work. I never tried it
Old 10-28-2017   #10
Ozruss90
Ozruss90's Avatar
Thanks for the feedback on those issues. Firstly, l will change globes to LED (good idea). Secondly, the rear hatch. I have read somewhere about the device that holds the hatch up a little. I’m guessing that’s to allow air to flow out if driving with no roof?? Are they available from the usual vendors like Zip etc?
Found them on Corvette Central site. Thinking of doing a group buy for us c4 owners in my group here in Australia. Can someone confirm that they are a good thing and work as intended before I go ahead.
Cheers, Russell
