Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Technical Questions
Old 10-07-2017   #11
QB93Z
QB93Z's Avatar
Default Re: Buzzing noises from glove box
That is good information. When you were cranking this time, did the lights on the cluster and the dash stay on?
Old 10-07-2017   #12
karlaw
Not sure becoz when using the jumper wire, I am standing by front tire.
karlaw is offline   Reply With Quote
Old 10-07-2017   #13
karlaw
Got no helper until next week, but I will try to rig up a mirror or something here now
Old 10-07-2017   #14
QB93Z
QB93Z's Avatar
OK, I understand.
Old 10-07-2017   #15
karlaw
So I checked, the dash lights and dic lights stay on while cranking.
Old 10-08-2017   #16
QB93Z
QB93Z's Avatar
OK. Now we can diagnose the cranking circuit. If you have gotten Section 8A of the Service Manual (Book 2) I am looking at page 8A-30-4 Chart # 1.
Do you have a 12 vdc test light? If not I suggest getting one at a auto parts store (sometimes called a Test Probe)
Connect the test light from the negative terminal of the battery to the connector you have on the "purple wire" which is the starter solenoid.
Turn the ignition key to START. Did the test light come on?
I am predicting the answer is no since you are using a jumper to crank the engine.
So, the next step is to test for voltage at the Clutch Safety Switch and then at the Starter Interrupt Relay. These items are under the drivers side hush panel, near where the VATS unit is hooked up. Do you know how to identify specific terminals on switches and relays?
Old 10-08-2017   #17
karlaw
Won't have the section 8A booklet until next Tuesday nite.
Test light connected from Negative to Purple wire, key on Start position, nothing , no power to test light.
4 month old battery when charged up using a good 40 amp charger for 3 hrs, then sitting for 10 hours, never seems to get above 11.9 volts, unless charger is turned back on, then I get the 13.2 volts.
I tested both sides of the connector as shown in photo I texted. No power . Not sure what that connector does. Haven't found the starter interrupt yet, having trouble getting my head under the dash,...going to get a hand held mirror to help see up there.
Not sure how to identify specific terminals....
I have attempted to try to get ohm readings on fuel injectors with plenum in place. I pull #1 inj fuse, then plug a lead wire from front half of fuse holder to a tester lead, then take other lead onto a paper clip and probe the pin sockets on the left hand ECM plug. I tried with battery disconnected .... Can't get anything to read.....I followed a description from Marc H, no readings. I wonder if I am not getting the right place to hook the grounding side in the fuse box ?
Old 10-09-2017   #18
QB93Z
QB93Z's Avatar
Please verify your readings from yesterday evening. Check for 12 vdc on the yellow wire that goes to the two wire connector in the top photo. The connector has two wires, yellow with a black stripe and purple. With the key in START, there should be 12 vdc on the yellow wire.
If you still get no voltage at the yellow wire, then the problem is in the Starter Enable Relay circuit or the Ignition Switch itself.
I think that the "other wire" with orange/white wire is for the under dash light so it should have 12 vdc when a door is open.
The Starter Enable Relay is turned on by the Central Control Module (CCM). The CCM gets a signal from the VATS Module and from the Theft Deterrent System.
These components are interconnected. The service manual says:
page 6E3-A-68: If the CCM does not send the correct VATS/TDS signal to the ECM, the ECM will not pulse the injectors and the car will not start
page 9D-2: The Starter Interrupt Relay: If VATS is not satisfied, the CCM will Reset (not allow start) for 2-4 minutes (crank and fuel disabled) and will not permit starting.
This is why the car will crank if you use the purple wire jumper, but it won't continue to run because the ECM and CCM are blocking the signal to the Fuel Enable Relay.
Old 10-09-2017   #19
QB93Z
QB93Z's Avatar
Do you know the history of this ZR-1? Did it ever run for you? Who installed the VATS interrogator? Have the CCM, ECM, Ignition Switch, VATS module, the Clutch Safety Switch, the Fuel Enable Relay, or the Starter Interrupt Relay been replaced?
Do you know how to use the Diagnostic Connector to check for Trouble Codes? What we need to do now is try to put everything back together and then follow the trouble shooting listed in the service manual.
I will be glad to try to help you do that.
By the way, what is you name and where do you live?
Old 10-17-2017   #20
karlaw
Hi Jim. My name is Robert D Adam , I live on acreage beside Red Deer, Alberta, Canada.
This red ZR-1 came from southern Minnisota , I bought it 12 years ago. It run perfect 3 years, then had a no start for 2 hours on a hot day in the city.
The car then had a couple more no start issues, and it got parked. It sat a 3 year stretch, then one year ago got it barely running, drove it 20 miles, it had maybe 100 hp, parked it for winter, tried many times to start this year. I discovered a bad fuel pump 1, so replaced both, cleaned tank, etc. That brings us to present day.
I rechecked testing the yellow/black stripe wire as in photo I sent, no power there even when using start position.
I installed the Vats Interrogator. Nothing has been replaced, other than fuel pumps, filter, and battery.
I did use a cheap $30 code reader, only got the code 12. Yesterday I took a bent paper clip and jumped the A & B in the ALDL connector, and I got NO codes, but the radiator fan came on full blast, and I think maybe some dash lights, just don't remember exactly.
I am going to find my code reader and retry for codes.
I now have that second book, the 8A section.
I do believe the ignition switch needs replacement, becoz last year there was intermittent connections in the start position, and now nothing in start position.
Also believe there is fuel enable issue, as it fires for a couple seconds, then nothing until sitting for 10 min.
