Old 12-13-2007   #1
rogerzr1
rogerzr1's Avatar
Default Exhaust Transportation
One of the zr1 net's members is having his exhaust changed out at Marc Haibeck. I want to buy his old exhaust but it is welded into a single piece. Does anyone have any ideas on a good inexpensive way to transport this, or am I out of luck? I live in GA.
rogerzr1 is offline   Reply With Quote
Old 12-13-2007   #2
Default Re: Exhaust Transportation
is it just tack welded together on the joints and still using clamps?
or fully welded? not sure how to get that shipped.
maybe drive the Z up from GA and get it installed?
what exhaust is it?
Old 12-13-2007   #3
rogerzr1
rogerzr1's Avatar
He said that it was TIG welded, I don't exactly know what that means.The exhaust is a B&B with x pipe.
Old 12-13-2007   #4
Take a picture of it... Bring it to a muffler shop and ask them were it should be cut to make it easy for you to reinstall. You can get it cut anywhere and most pipe benders can hook you up later anyway. You could try UPS one piece but I bet it would end up getting destroyed unless crated!! It doesnt take much to damage the mufflers and tips. You can get the piping anywhere.
Old 12-13-2007   #5
Marc would have to since it is at Marc's shop
Old 12-13-2007   #6
Yes thats why I suggest you take a pic to your local muffler shop so you can tell Marc where to initially cut it.
Old 12-13-2007   #7
flyin ryan
flyin ryan's Avatar
i bought a stock system from K.W. in FLA., it came up in one piece. he just bolted a 2x4 in between the muffler hangers & bubble wraped it up. came via Roadway, i'm pretty sure they just straped it to the wall of a van. made it fine. was about $200 bucks but it came long way. i can't complain.
Old 12-14-2007   #8
HIZNHRZ
Because of superior arc and weld puddle control, TIG allows you to create clean welds when appearances count. Because the heat input is often controlled by pressing on a foot pedal, similar to driving a car, TIG welding allows you to heat up or cool down the weld puddle giving you precise weld bead control.
The system is not tack welded. The seams are filled. There are no hangers holding it together. As I was telling rogerzr1, it is basically a new system. It was purchased, welded, and installed on a 91 ZR1 in 2004. In 04, the car had ~7K miles on it; today it has just south of 10K miles. The BBB system is stock and bolted directly to the collectors of Watson headers. Included in the exhaust system are Random Technology bullet cats (3"I/O) and Stainless Works X-pipe. The X-pipe was added when I had the car dyno tuned in 2005.
What was the purpose of the 2X4 between the muffler hangers? Did it prevent the system from bending or protect the mufflers or both?
Old 12-14-2007   #9
Somehow I knew it was your system he was talking about.
Old 12-14-2007   #10
flyin ryan
flyin ryan's Avatar
that was the idea. it helped support it a fair bit too.
