![]() Join Date: Mar 2017
#3 | |
“A coilover suspension upgrade was installed. The shock absorbers were reconditioned and revalved to the Moraca valving. The front springs are 550 lbs./inch. The rear springs are 350 lbs./inch. New boots were installed on the front tie rods. Heat shields were installed to protect the boots. The ride height was set with six threads in the front and 12 threads in the rear. When adjusting the ride height the threaded sleeve must be held to prevent rotation.” |
