Old 08-06-2005   #21
Ron Ashcraft
Ron Ashcraft's Avatar
Default
Just a for what it is worth,
You might tighten your C Beam Bolts. I never experienced the problem until the engine started moving around under hard acceleration due to loose C Beam bolts.
I did replace the OEM Duct with a heavier Smooth Silicone duct.
Good luck
Ron
Ron Ashcraft is offline   Reply With Quote
Old 08-06-2005   #22
ffvetteman
Default
Loose C-beam bolt? Never would have thought of that. I have only been under the car once, so I do not know if they are loose. I dont have the car out that often, but when I do I seem to get on it often.
ffvetteman is offline   Reply With Quote
Old 08-06-2005   #23
Default
Do both. Install c-beam plates or tighten the bolts down. You also need to get the reinforced duct.
Old 08-06-2005   #24
Default
I have a spare duct also if anyone needs one its off the 90 I used to have, drop me a message..I put one of Mark's on both cars last year so I stll have a spare for the 91.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-07-2005   #25
ffvetteman
Default
Ive got another set of beam plates, maybe I will put them on the ZR-1. I bought 2 sets when they had the group purchase and put one on my 84, but I bought another set for the other 84, and never put them on. Now I am selling that 84, so I have the other set. I will put that on the Z.
I have not searched yet, how hard is it to located another duct and how much is it? Just so I can have a spare. Now he still sells the sleves? How much are they? I was wondering if the price changed if he does not include the duct any more.
Old 08-08-2005   #26
Default
The duct is not available from GM anymore so you would have to find someone buy one from. You have to ship the duct to him then he installs it and ships it back.
Old 08-08-2005   #27
Default
Just pay the shipping & it goes to the first to send me a PM..when you get yours back just pass it on
Steve
1990 Red/Red #1473
Old 08-08-2005   #28
ffvetteman
Default
Oh Oh Ill take it,!!!
you have PM
Old 08-09-2005   #29
Default
you have PM
Done you have a reply
Steve
1990 Red/Red #1473
Old 08-09-2005   #30
Bell Curve
Bell Curve's Avatar
Default
Originally Posted by RiceEatingZR1
I think it helps a little because you can hear it sucking the air in when you hit the throttle. but as far as feeling more power you don't really feel it. so my guess is that if it adds any HP it would be like 1 to 5HP at the crank. you more then likely would lose that by the time it gets to the wheels.
You might be right but I remember reading something where before and after dynos were done, and the claw set up lost a little HP instead of gaining any. I think the conclusion was that the stock intake was about as good as it is going to get and that Chevy had at least one aspect that could not be modified any better.
Bell Curve is offline   Reply With Quote
