Old 07-14-2017   #11
BigJohn
BigJohn's Avatar
Default Re: Antenna Mast and Grommet
GM Part#10067979
Old 07-14-2017   #12
efnfast
Originally Posted by BigJohn View Post
I really don't think my car has either!
Radio delete John?
Old 07-14-2017   #13
GM Part#10067979
10067979 Is for standard Corvette.
Old 07-14-2017   #14
1990 quasar blue
Originally Posted by USAFPILOT View Post
i still need a grommet for my car...gl
I know they were tough to find a couple of years ago when I needed one. I imagine that they're about nonexistent now. The good news is I bought two. I used one and sent my other one to a forum member so he could get them made. I'll have to send him a message and see if he's still interested. If not maybe he can send it to Jerry. Hopefully we can get them remade one way or another.
Old 07-14-2017   #15
If the motor is running that tells me the mast is broken and the thing needs to come apart. One person can install the mast with the antenna housing in the car but it's a bit tricky. And also,nobody mentioned that there is a nut at the top of the housing that needs to come off in order to get the new mast in the housing and this nut takes a special socket to get it off,it usually comes with a new mast. Also,an antenna from a 93-96 will work in an earlier car but the wiring needs to be switched around. Early has external relay later has internal relay.
Old 07-15-2017   #16
Jagdpanzer
Jagdpanzer's Avatar
One on eBay
http://m.ebay.com/itm/302376943367?_mwBanner=1
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-15-2017   #17
jss06c6
Mike,
If you can wait until I get my '91 off the lift we can easily pull the assembly from you '90 and put it on the bench to diagnose..
Steve
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 07-15-2017   #18
BigJohn
BigJohn's Avatar
Originally Posted by efnfast View Post
Radio delete John?
The radio is there but I have never turned it on.
Old 07-17-2017   #19
MickeyD
Originally Posted by jss06c6 View Post
Mike,
Steve
Give me a call when your ready! Thanks.
MickeyD is offline   Reply With Quote
Old 07-17-2017   #20
jss06c6
Will do!
Sent from my XT1585 using ZR-1 Net Registry mobile app
