Old 06-26-2017   #1
tpepmeie
Default WTB - Plenum insulator plates
All,
I need to source a set of phenolic plenum spacers. Wish I'd bought Lee's last year for a good price.
Anyway, I'm hoping to use these to correct a slight misalignment I'm having with the ports on my personal engine. Would rather grind on the phenolic to make a smooth transition between plenum & IH.
Old 06-27-2017   #2
Vette Guy
Vette Guy's Avatar
Default Re: WTB - Plenum insulator plates
Todd,
I've been running a set for years - I purchased 1/4" phenolic sheet from NORVA Plastics when I lived close to them (they sell excess job material on eBay), and made my own using the gasket as a template. The material is very easy to work with and cut/shape/sand as needed. They are currently selling 1/4" sheets on eBay (G10).
Good Luck!
Regards,
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 06-27-2017   #3
spork2367
Originally Posted by Vette Guy View Post
Todd,
Good Luck!
Regards,
G10 is not the same as phenolic. Phenolic is cotton, linen, or paper. G10 is fiberglass. It is more dense, and much harder on tooling. Just an FYI. I was a manufacturing engineer in a job shop where we sold and machined a lot of both.
Old 06-27-2017   #4
ABBEZR1
ABBEZR1's Avatar
Not to Hijack a thread but what is the advantage or disadvantage to these spacers. I've never really got a straight answer from anyone. I have a set on my car that a previous owner had put on and I thought about removing them when I do my first plenum pull if they are not helping the performance of the car.
Steve,
_______________________
1990 Bright Red/Black #946
B and B X-Pipe
Stainless Works Long Tube Headers
Cat delete
49th Street Rockers
Haibeck Chip and Tune
ABBEZR1 is offline   Reply With Quote
Old 06-27-2017   #5
Principal Advantage: Thermal insulator for plenum, to impede heat soak from the engine
Other Advantage: Marginal increase in air circulation under plenum, aids in cooling of plenum & DIS Module.
Disadvantage: 1/4" spacers frequently result in intake contact with underside of hood.
Disadvantage: Requires some bending of vacuum line to PCV top connector.
Disadvantage: requires 2 sets of plenum gaskets. & longer bolts
Old 06-27-2017   #6
I know Todd needs them for another purpose, but the spacers introduce one more place for a vacuum leak.
Old 06-28-2017   #7
tpepmeie
^^^ what he said. I'm not doing this for any performance impact, and I doubt the claimed benefits of plenum insulation are even measureable!
I just need the spacers to improve the transition interface between the housings and plenum. What happens, in my case, is a slight decking of the block, combined with skim cut on the cyl head deck, and a thinner MLS gasket = the heads sit fractionally lower. The plenum ports no longer line up perfectly with the housings, so I need to fix that. We're talking millimeters here.
One added consequence, the extra 1/4" or so should move the natural tuned length of the intake slightly lower (perhaps 100 rpm). Peak torque on Build 1 was 5800 rpm, which is more or less where the factory HP peak was, and where the stock runner length is tuned.
Old 06-28-2017   #8
Todd, I have a used set of 1/4" on an engine I acquired last year.
Old 07-03-2017   #9
HAWAIIZR-1's Avatar
Todd,
If you don't get the set from Jerry, I have a new set that I bought from Lee earlier this year. It sounds like you need it more than me.
Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
