Old 06-05-2017   #11
Default Re: 1990 finally finished body wise
Looks great, the white stripe does set it off.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-05-2017   #12
225Kzr
225Kzr's Avatar
GC......It's beyond great......it's simply stunning! Partial to the black A-molds with the red (and no one chime in with the red/black wheel thing) but are they GS or ZR-1 offset?
225Kzr is offline   Reply With Quote
Old 06-05-2017   #13
Ccmano
Beautiful! That combination works really nice together. Is there a thread around on how the auto trans got in the car?
H
Old 06-05-2017   #14
They are GS 50mm If I find a pair of 36mm offsets that need refinishing I would get em pced however I am not in a hurry in the moment unless a pair turn up. GC
Old 06-05-2017   #15
H
Look in Schrade's "Chucks" old posts here it was documented pretty well. At first it was a total disaster lots of sub standard work and Chuck took em to court and won. He had everything done correctly locally in North Carolina and with the exception of my installing a factory linkage cable to replace a fabbed unit on the underside everything now works as it should. Before hand the car would not actually lock into park. Now it does as it should. If you would look into the car it looks like a L-98 auto. Until you see the badging and/or pop the hood.
It also cost about 3 times more than planned after sourcing the parts to find a "responsible shop" to do the work correctly. From the programmer controller to the fabrication of what was required to mount the transmission. This is not a mod that can be done on the cheap he was charged $8500.00 before the lawsuit. Most of us here thought that amount was criminal gouging as did the courts.
Old 06-06-2017   #16
JimZRyd
JimZRyd's Avatar
Looks great!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 06-07-2017   #17
Thanks Fellars.
Old 06-07-2017   #18
rush91
Very nice! It looks like that was a factory paint option
Old 06-07-2017   #19
KILLSHOTS
Looks awesome Daryll!
Old 06-07-2017   #20
Thanks Chris !
