#81 |
![]() Join Date: Jun 2004
Tom,
You have an email coming your way....... ![]()
#82 |
![]() Join Date: Mar 2014
Carter, email replied too.....looks great.....
#83 |
Think I cornered the market on these....lol
PepBoys has the best "Help" section IMO. They have way more of a selection than AutoZone and Advance Auto. Ended up going to three PepBoys to get the rest of the connectors. Did a cut on two and they fit perfect. There is also some flexibility with these connectors in that the attaching tubes can move to accommodate their final attachment. For anyone that will have the need to address the original connector in the future, IMO these vacuum tube connectors should work just fine... I own the market on these.... ![]() ![]() the cut... ![]() fitting good... ![]() lines fit very tight & snug....no reason to come loose.... ![]()
#84 |
Looks better than OEM
Thanks for sharing
#85 |
Thanks Phil....yes it is an OEM alternative.....lol
The only thing that I have concern about is how well these will hold up with the engine heat. As the original connector is thicker in the elbow and again the "new" ones are more pliable, which is not a bad thing... I guess I'll find out in time!!! lol I could spend a lot of time under here cleaning everything, but if I do that I won't be driving the Z soon.....just cleaning what I can get to ![]() I also changed out the vacuum reservoir. I have a few NOS replacements, so I thought why not change it out....while I'm in here... reservoir removed....area needs a clean-up... ![]() cleaned and looking better than before.... ![]() new unit in..... ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 05-12-2017 at 06:28 PM. |
#86 |
Send me a pic when installed......
#87 |
![]() Join Date: May 2017
#88 |
Hey Tom
I know I'm late to the game but here is some pics of my plenum pull and some, I hope its helpful https://www.facebook.com/media/set/?...1&l=8f46fa4533 Dave ![]() Last edited by mgbrv8; 05-15-2017 at 01:04 PM. |
#89 | ||
There isn't really any link for the test, George told me of a procedure using a flashlight to help determine if your primary and secondary blades are fully closed. All I did was turn out the lights, so that you have complete darkness and shine the flashlight through the front and back of each blade. Now as I have found out, this is more of a test for the secondary blades as opposed to the primary blade. Reason being as was mentioned to me, is that the primary blade does not close completely, so there will be light that does shine through on that blade. Dominic has a procedure to check out the primary blade by using a thin piece of paper and see how much resistance you have pulling it through the bottom of the primary blade when in the closed position. It should pull through with resistance. Just to be clear, at this point I am not sure or exactly know what is the cause of my idle issue. I will have to wait until everything is back together and even then I may not know the actual cause because I am making adjustments and checking everything out under the plenum, and the TB. If it still persists after, I would definitely lean towards the TB. Hope this helps..... Quote:
![]() Thanks for recommending your page...... ![]() ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 05-15-2017 at 09:29 PM. |
#90 |
Before I continue on today's events, this is what I received in the mail today, my first birthday gift to myself a day before.....
![]() Carter did and always does an outstanding job....thank you sir!!! Now if I can only get my old cover off my TB..... ![]() ![]()
