Old 05-12-2017   #1
Ronstar
Default banski suspesion parts
anybody got banski rear suspension on their Z? thoughts?
have heard some coilovers will interfere with clamp on trailing arms?
Ronstar is offline   Reply With Quote
Old 05-12-2017   #2
Default Re: banski suspesion parts
I am running DRM coil overs and there are no problem with clearance with my Banski trailing arms
Old 05-12-2017   #3
Ronstar
Do you have all the banski pieces or just the trailing arms? Are you happy with them?
Old 05-12-2017   #4
BigJohn
BigJohn's Avatar
Some coil overs rub on half shafts!
Old 05-13-2017   #5
Jitse
Full Banski rear suspension together with Coilover kit from DRM, no clearance problems at all.
If you like I can send pictures to you....
Jitse is offline   Reply With Quote
Old 05-13-2017   #6
rkreigh
love the banski stuff. the parts are high quality, much lighter than stock, and the heim joints eliminate the "sticktion" caused by the rubber bushings rubbing the mounting bracked to free up the rear travel tremendously.
I haven't yet seen if it helps the 60 ft time and the diggs but the handling and ride is noticeable better.
I have the DRM shocks and indeed did have some problems with the springs rubbing the half shafts until I fiddled with the spring a bit.
overall I'd for sure do the banski stuff, really like their products.
Old 05-14-2017   #7
Ronstar
Are you guys with the banski stuff using the drm brackets as well?
