Old 04-19-2017   #1
MuRCieLaGo
Default ACDelco vs Denso plug wires
Hi,
I'm looking on RockAuto to find which plug wires I should order and these two are basically the same price. Which wires do you guys use?
Thanks!
Old 04-19-2017   #2
Default Re: ACDelco vs Denso plug wires
DELCO. Good enough to be OEM good enough to be on my daily drivers
Old 04-24-2017   #3
Young1
Young1's Avatar
I just ordered the Denso. Will be installing this weekend. I will give report.
Old 04-24-2017   #4
Packard was the OEM for the ZR-1. They don't have the ZR-1 silk screening but do have the exact same wire, sheen & color as the originals, if that matters.
http://www.jerrysgaskets.com/wire-se...lug-90-95-9b2/
They are about twice the cost but then the ZR-1/LT5 was at least double the cost of the base Corvette at the time.
Old 05-01-2017   #5
Young1
Young1's Avatar
The Denso wires fit just fine. Solved my idle and heat soak issues. I recommend them for the price
Old 05-03-2017   #6
MuRCieLaGo
Well I ordered the ACDelco, following GOLDCYCLON's advice. Wasn't sure about the "Packard" brand Jerry so that's why I did not order from your website...
So it solved your idle issue Young1, hmmmmm. I've been having idle problems since I bought the car, I can't wait to install them. Will do,when I come back from the ship I work on now.
Thanks guys!
Old 05-03-2017   #7
I understand your concern. Packard was the supplier for the original LT5 plug wires when the engines were produced and for GM Parts inventory. I don't know who makes the plug wires for ACDelco now, but it's not Packard. AcDelco doesn't manufacture anymore, it's all outsourced.
The quality if the ACDelco wires is probably similar, but the Packard wires are identical to the original LT5 wires, right down to the color, sheen & quality, only the LT5 silk screening is missing.
Old 05-03-2017   #8
Jagdpanzer
Jagdpanzer's Avatar
Packard has been around for a long time making excellent quality plug wires. Back in the day we used solid core Packard plug wires on our natural gas irrigation well engines. They were the only ones that would hold up season after season. Drove AM radios crazy.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-03-2017   #9
Unfortunately MSD does not offer wire set for LT5 anymore. I still have the set that was replaced by the Magnecors recently.
Old 05-03-2017   #10
Do you remember the Rajah connectors for the plug end?
