![]() Join Date: Jul 2016
So I now have the intermittent DNS (dreaded no start) on my 91 Z. I want to try to bypass the clutch safety switch to see if that helps. Can I just unplug it and jumper across the plug or is there more to it?
Sent from my XT1080 using ZR-1 Net Registry mobile app |
![]() Join Date: Jul 2007
![]() Join Date: May 2007
Verify that both battery terminals are clean and tight. Disconnect any after market systems attached to the battery terminals.
Put the ignition key to ON, Engine not started. Note the battery voltage on the instrument panel. Turn the key to start, while watching the battery voltage meter. If the needle does not deflect, then investigate the starting circuit, ie clutch switch, VATS, TDS. If the volt meter does deflect, it means that the starter solenoid is energizing but the solenoid contacts are not passing current to the starter motor. Rebuild the starter solenoid or replace the starter. NOTE, keep this procedure handy because it has to be done when the car won't crank. For an intermittent problem like you stated, you will have to wait until the next failure. Good luck, Jim Last edited by QB93Z; 04-24-2017 at 06:32 PM. |
#4 | |
EXACTLY the same symptoms I had when the starter solenoid contacts were dirty.
OK, so it happened again. I watched the volt meter and the needle didn't move when I turned the key to start. I was able to get a push start. What's the next step?
TDS is the theft deterrent system, the resistance chip in the ignition key that is checked to allow the computer to allow the starter circuit to energize.
The next step is to rebuild the starter solenoid or replace the starter. Jim |
#8 | |
If it is Hot start only, it is the contacts of the solenoid. I chnaged the wiring a bit to minimize the solenoid electrical path, I still ended up pulling the starter and replacing the contacts.. The Challenge is diagnosing while hot..
But because it is only when hot, the contacts make more sense than the clutch switch
#10 | |
