Old 03-28-2017   #21
Livin' in the 80's
Livin' in the 80's's Avatar
Default Re: Oil Cooler Line replacement
Originally Posted by Mystic ZR-1 View Post
I installed a set from Zip a few years ago.
They fit fine and no leaks so far.
Awesome! Did it make a giant mess when you disconnected the lines? I am planning on stuffing rags all over the place to avoid oil all over the place.
Livin' in the 80's is offline   Reply With Quote
Old 03-28-2017   #22
BigJohn
BigJohn's Avatar
You ever get the new radiator installed?
Old 03-28-2017   #23
Mystic ZR-1
Mystic ZR-1's Avatar
No big deal and not too much of a mess. Like you suggested, pack some rags under the connections. Getting the fittings on the motor can be tough, I used a large adjustable wrench because I had nothing that big. Once they're broken loose, you should be able to un-screw them by hand.
Big John: no, not yet, but soon...
Old 03-28-2017   #24
billschroeder5842
billschroeder5842's Avatar
I made the mistake of going with "OEM" equivalents which leaked from the hose after 500 miles.
I went with Jerry's and have been happy. Jerry's also have the benefit of being flexible so you can do a bit of routing and bending around other hoses for proper clearance.
I had less oil spill than you think, but lots of rags are the order. Remember the Teflon tape.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 03-29-2017   #25
Billy Mild
Get Jerry's lines. Also don't go all he-man on it like I did or you will just break the seal from being too tight. Ask me how I know.
Old 03-31-2017   #26
Livin' in the 80's
I rolled the dice on the Lines from ZIP and installed them last night. I used a 1 1/2" open ended wrench and tapped on the wrench with a lead hammer and they loosened right up. I used a little silicone to hold the rubber o rings in place like a glue. I didn't over tighten any of the fasteners.
Old 04-15-2017   #27
Livin' in the 80's
Well, My roll of the dice didn't pay off. Don't buy the Oil Cooler lines from this place!!!!!!!!!!!!!!!!. One hose completely blew apart and made a huge mess. I will be having a discussion with ZIP on Monday. Pics to follow.
Old 04-15-2017   #28
billschroeder5842
Sorry! That sucks! Get your money back from Zip and call Jerry. You could have your new lines dellivered and installed by Wednesday.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 04-15-2017   #29
Livin' in the 80's
Asphalt driveway ruined-entire car covered in oil, garage oil filled, hopefully the engine is ok. total BS I will be letting everyone know the deal with this crap material
Old 04-16-2017   #30
Livin' in the 80's
DO NOT buy ZIP oil cooler lines. Total garbage!!!!!!!!
