Old 04-13-2017   #1
Default WTF! Voltmeter screwy?
So I just finished installing my appradio 4 and it works great. Nice day out, so thought I would take car out for a bit of a shakedown run. Everything working well. Just about coming to the end of the ride and I notice my voltmeter looking like the first pic. However, NO BAT light. Then I shut motor down once in the garage and the voltmeter is in the position of the second picture. The radio works fine. Everything works including Siri, Maps, CarPlay etc. I am getting a staticy noise coming from the passenger side front. It even did a series of clicks which got progressively quieter then apparently stopped.
Old 04-13-2017   #2
Default Re: WTF! Voltmeter screwy?
I'm posting second pic here because for some reason, I can't post more than one pic per post.
Old 04-13-2017   #3
Just went out and checked digital readout and it shows normal voltage. NOW w Motor running the meter is reading correctly. W Key Off, its still off the scale.
Bad Voltmeter?
Old 04-13-2017   #4
nelson007
nelson007's Avatar
Bad Voltmeter?
It might be a dropping resistor in series with the volt meter. They sometime use them for calibration.
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 04-13-2017   #5
Jagdpanzer
Jagdpanzer's Avatar
According to FSM page 8A-82-0 the instrument cluster voltmeter reads fuse #27 voltage directly across the line to ground. If a poor connection is not involved then the gauge is probably suspect.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-13-2017   #6
Dom if the voltmeter turns out to be the problem I highly recommend Batee.com for the repair. GC
Old 04-14-2017   #7
Good to know, Daryl! I saved the link.
Dom, the large connector at the back of the cluster sometimes gets oxidized (frosted), resulting a host of weird chit starts happening with the cluster - or so it did with mine.
I was able to "fix" it by cleaning the pins and spraying them with electronic cleaner/lube (and that goes for any connections between the gauge, ground, and "B+".
Just a thought.
P.
Old 04-14-2017   #8
Just a thought.
P.
Thanks Paul. I just put the center stack back together after installing the appradio4. And now take the cluster apart??? I may leave till after BG. It also seems like I have a bad front amp. Its making all kinds of fuzz and clicking noises. Sounds a bit like a pod of dolphins. My main concern was that I was having another issue w the charging system and apparently I don't.
Old 04-14-2017   #9
Jagdpanzer
Jagdpanzer's Avatar
The + feed is common to all the analog gauges so if you had a voltage issue the other gauges would also beacting up.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-14-2017   #10
So Phil, you are confirming its the volt gauge itself. And oddly now, the gauge is reading correctly when the motor is running whereas it was not when I drove the car yesterday.
