Old 04-03-2017   #1
White Bullet
White Bullet's Avatar
Default Replacing clutch need some info.
I need to replace the clutch and have researched the solutions links. I plan to use the LUK 04113 kit. My questions are is this kit correct for a stock setup? The information I have found says it is however I would like the experts here to confirm. Does this kit work with the dual mass fly wheel? Will it any modifications as in different bolts to install?
Link to info: https://www.carid.com/luk/repset-clu...pn-04-113.html
Any other information you may have would be helpful. Thanks.
White Bullet is offline   Reply With Quote
