Just wanted to post this for someone searching with Brake light problems.
Problem: 3rd brake light works, but the lower brake lights don't. Checks: Taillights work Turn signals work (L & R) Hazards work Brake switch is OK Fix: I found the turn signal flasher shorted, replaced and all is working. ![]() |
Good deal craig. Gald you found it.
![]() Join Date: Dec 2004
Thanks for sharing that tip!
![]() I'm putting that in my shop notes! ![]() ![]()
