Old 02-03-2017   #21
WVZR-1
Default Re: Front inner fender skirt/cover removal
Excellent work Tom!
Going back on will you be using rivits or torx screws?
I should have sufficient hardware for you also!!
Old 02-03-2017   #22
Jagdpanzer
Jagdpanzer's Avatar
Thanks Dave, I very much appreciate it.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-05-2017   #23
Roadster
Roadster's Avatar
Made more progress today....getting there.....lol
My selection of tools for this job getting the rivets out....the 5 lb sledge is one of the best tools I own...it even loosens bolts when even a breaker bar won't do....
RS before disassembly...
RS under hood after panel removed...
RS after cleaning....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-05-2017   #24
Roadster
Roadster's Avatar
RS headlight bucket before...
RS headlight bucket after...
RS panel removed...you can see how cruddy it was from all of these years, the LS looked exactly the same....
RS topside panel cleaned....
RS bottom panel cleaned, but needs help!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-06-2017   #25
Roadster
Roadster's Avatar
Recommended by another car buddy.....paint for plastic......
Picked these up today, will do one bottom side panel with Rust-Oleum Flat Black and the other bottom side panel with Krylon Fusion Satin Black....
Also picked up a sanding block, as I have to sand those pieces, hoping it will smooth out the stone digs somewhat, we shall see!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-08-2017   #26
Roadster
Roadster's Avatar
On the RS of this pic you can see the difference from the LS, all those marks are actually road grime, oil and whatever else you pick up along the way when driving in the rain. Add that to 23 years of use and you have a build up that is fun to remove...using a sanding block and a small screwdriver, removed all of the imperfections, ready for paint...
Used the Rust-Oleum paint, not to satisfied so far with the way it laid. I may have been to anxious and put on too much of a heavy coat. The longer it dries, it does seem to eliminate those fish eyes.....but I may have to re-sand and start over again...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-08-2017   #27
Roadster
Roadster's Avatar
Experimentation still needed....part is dry, shade of finish is fine....but have to figure out how to get a smooth finish allover!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-08-2017   #28
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Tom,
You may have silicone residue on those fenders.
Use one of the Eastwood type products that removes that before painting.
Think its called PREP.
No matter what you cleaned or roughed the surface with, silicone remarkably
hangs on tough.
Wish it would on my tires!
Best of luck!!!
Marty
Old 02-08-2017   #29
Roadster
Roadster's Avatar
Originally Posted by DRM500RUBYZR-1 View Post
Tom,
hangs on tough.
Best of luck!!!
Marty
Thanks Marty, I was using mineral spirits as a prep....maybe not the correct product to use on this surface. Didn't even think about silicone being on there!!!
Will check out the Eastwood product.....appreciated....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-08-2017   #30
WVZR-1
I don't know that there's any rattle can that sprayed directly has adhesion capabilities for the product. I don't know that the GF PP is a plastics type or not. I'm accustomed to seeing the "TYPE" in a trademark or circle or something of the sorts. Could they be assumed to be PP? Maybe - very likely!
If you were to use maybe SEM 3986 Adhesion Promoter it might do much better. Very HOT soapy water wash first after maybe the use of a silicon remover BUT when using the correct adhesion promoter maybe you could get a much better finish. Durability might always be an issue! Visit an auto refinishing/auto body supply house in the area maybe.
Here's a 3986 product user guide. Painted lots of plastic after using this stuff
http://www.autobodytoolmart.com//pdf...omoter_tds.pdf
GFPP maybe?
http://www.plasticsgroup.com/polifil_gfpp.php
