Old 01-11-2017   #1
ssrszz4
Default Alignment
Should the front and rear both need too be aligned?
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
Old 01-11-2017   #2
G8nightman
G8nightman's Avatar
Default Re: Alignment
I would do it just so your sure that everything is in spec
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 01-11-2017   #3
ssrszz4
So I looks like the rear of the zr1 was built to be aligned kind of what I was asking. Also wondering if most shops are set up to do this?
Old 01-11-2017   #4
G8nightman
G8nightman's Avatar
Yes you can adjust the rear.
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 01-11-2017   #5
PhillipsLT5
PhillipsLT5's Avatar
https://www.vbandp.com/instructions/...ent-specs.html
Old 01-11-2017   #6
RussMcB
I'd say a four wheel alignment is pretty critical for our cars. You need all four tires pointing in the right direction and proper camber. Otherwise, tire wear and sub-par handling.
I guess that's not really unique to our cars. Any performance car with independent rear suspension. I think even Mustangs have that now. :-)
Old 01-11-2017   #7
ssrszz4
Thanks for the great info.
Old 01-13-2017   #8
batchman
Whatever you do with your alignment, don't just go to a chain and get the factory specs. Get to a shop that will work to your specs and try the VB&P spec whose description best matches your need.
Like any performance car, alignment specs matter - not as sensitive as tire choice but is the next priority in how the car works with the surface.
Cheers,
- Jeff
Old 01-13-2017   #9
ssrszz4
Thanks Jeff
