Old 01-06-2017   #1
rush91
Default Loud bang when switching between vent modes...
I've noticed this ever since I've had the car. A loud bang / thump / pop whenever I switch between vent modes. And doesn't matter if I'm using the A/C or heat. But for instance if the unit is set on the floor vents, and I hit the button for the dash vents, there is a VERY loud bang....Like something is hitting the underside of the dash. It only happens when I hit the button for the dash vents, or the dash/floor vent combo button. I haven't really dug into this yet, as I hardly use the A/C or heat, which both work fine. The unit works fine, all vents blow out hot or cold air.
Old 01-06-2017   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Loud bang when switching between vent modes...
Your description indicates that you are able to divert the airflow successfully as commanded, to defrost, upper and lower vents, Correct?
Further, it seems that you are able to command temperature changes and all responds as requested, Correct?
Does the noise happen on every selection of airflow every time, or just the first change?
It sounds as if the long HVAC tube connecting the passenger side to center may not be properly secured or fastened, has the heater core been replaced?
It would be helpful to determine what immediately precedes the noise, i.e.
does it happen after you invoke the diversion of air, or as it is changing?
The blend door could bang, but we need to understand is it temperature invoked or outlet invoked?
I am suspecting outlet invoked.
Marty
Old 01-06-2017   #3
rush91
Marty
Yes. I can divert the air flow to any vent and the air comes out fine. Also the climate controls work fine. I can set it to auto for any temp, and works fine.
It happens when I switch the vents on the 1st change. And doesn't happen if I switch back after that. There really is no noise that follows the slapping / banging noise. As far as I know the heater core is original, and the I have no issues with the heat.
This blend door you speak of lol....That to me sounds like what is happening. Like that door, when switching vent modes, slaps against something. Or bangs loudly when switching. Is this a part that wears out over time?
Old 01-06-2017   #4
billschroeder5842
billschroeder5842's Avatar
Is there any way that you can make a video with sound of the problem?
Sounds are tough to diagnose as one mans bang is another mans smack, thud or whack.
Vocabulary is a tricky thing.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 01-06-2017   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Mine does the same thing after start up.
Believe it's the blend door, does it in every mode except off.
Pretty sure it's supposed to move after start up,
but it shouldn't bang? Just started doing this recently.
All AC/heat controls appear to work OK.
Sounds like the same problem rush91's having?
Old 01-06-2017   #6
BigJohn
BigJohn's Avatar
Does it only happen when it is off the jack-stands???
Old 01-06-2017   #7
rush91
I will try to get a video of it, or sound clip somehow. But the noise sounds like someone is hitting the dash.....Makes me winch when it happens, same as someone who gets in/out of my Beast and slams the door lol.
Old 01-06-2017   #8
rush91
Sounds like the same issue to me. I'm going to go through the books tonight and see about this blend door. But that is what it sounds like, its smacking up against something.
Old 01-06-2017   #9
My 91 does this every once in awhile but I do know the sound. It's almost like the door is either stuck and then releases with force or it my be getting too much vacuum.
Old 01-07-2017   #10
MickeyD
My black 90 does that. Only has 2200 miles. I wouldn't worry about it.
MickeyD is offline   Reply With Quote
