Old 12-02-2016   #1
billschroeder5842
billschroeder5842's Avatar
Default Tail pipe halfsies?
So I'm finding all sorts of do-dads on my ZR1.
I noticed that my factory exhaust only has the outside tail pipe that "works" and the inside seems to be decorative?
Is that right?
Anyone do anything different other than swap out the system?
Thanks!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 12-02-2016   #2
msuhanek
Default Re: Tail pipe halfsies?
My 91 ZR-1 works off long tube stainless headers and true duals. Late model Vettes druel when I pull up at events!
msuhanek is offline   Reply With Quote
Old 12-02-2016   #3
Fully Vetted
Fully Vetted's Avatar
Is that right?
Thanks!
Not uncommon. I know my Corsa's are like that. Although, if you have the original exhaust then you should have one wide rectangular tip on each side not two round tips per side.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-02-2016   #4
efnfast
Early models had two square per side. Well, square like the tail lights.
Old 12-02-2016   #5
billschroeder5842
Yep, mine is like that.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 12-02-2016   #6
Only one outlet functions per muffler.
Old 12-02-2016   #7
Here's an exhaust that is "halfsies" when I flip the switch.
Old 12-03-2016   #8
HAWAIIZR-1's Avatar
You show off.......lol. I love that mod.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 12-03-2016   #9
The cams help too.
Old 12-03-2016   #10
Is that right?
Thanks!
Hi Bill- This has been discussed over the years and relates to the construction of the muffler to reduce resonance. There should be several threads related to resonance that discuss this. One exhaust pipe goes into each muffler and two tailpipes come out, but only one actually flows exhaust straight out; the other is mostly cosmetic. If you cut one of your mufflers in half horizontally you would find that the rear two thirds of each muffler is a closed chamber with a 1 " or so diameter tube going into it. (Sometimes there is a small 1/2" dia. tube that goes through the chamber but doesn't connect with it to flow just a little bit a exhaust. Not sure why other than a bit more pressure relief).
The chamber is called a Helmholtz resonator and it engineered to be a specific shape and volume to cancel out one of the two main natural frequencies that our engines generate that create the intense resonance or "droning" under light to moderate load at 1800 and 3400 rpms that you have heard many with certain aftermarket exhaust systems complain about. The exact shape and size allow for sound waves of a specific frequency to enter the chamber, bounce around and cancel each other out. The center resonator also has such a Helmholtz resonator for the 3400 rpm frequency of 230 Hz; the mufflers deal with the 1800 rpm one of 120 Hz.
Sometime people drill out the dummy tailpipe thinking they will get better performance and a better sound. They are rewarded with the same performance and a loud droning at 1800 rpm. Bad idea. Corsa also uses Helmholtz resonators, and I suspect some newer ones of other makes now do too. Most of my research on this was done in the 90s; I am sure that several manufacturers hove found solutions to this problem. At the time, only the stock and Corsa systems tamed the resonance. Hope that helps--Bob
