Old 10-10-2016   #11
Mr Blue
Default Re: Radiator shroud hole plug
McMaster Carr should be able to supply this
Mr Blue is offline   Reply With Quote
Old 10-11-2016   #12
Another option if you have a lathe is whip one up out of aluminum.
Old 10-11-2016   #13
WVZR-1
I have an upper support that's inked as a '90 with the plug and on the back-side it's ID'd as an RE10 - I ain't knocking it out to measure the hole and I might try to ID RE another time.
OP - you've got the hole how about a dimension?
If you GOOGLE - "button hole plug" OR "flush plug button" you'll be presented with 100's of choices. I believe those very likely a correct very generic application description. In town "local" I'd think there's likely nearly a dozen choices - maybe more.
There was a 1" GM# 4410574 that if were dimensionally correct looks to be maybe either the plug or very similar. Of course it's NLA so .... That's the only "rubber" I've seen part #'d.
Old 10-11-2016   #14
RussMcB
Originally Posted by WVZR-1 View Post
If you GOOGLE - "button hole plug" ...
and make sure you type that carefully. :-)
Old 10-11-2016   #15
bdw18_123
Old 10-11-2016   #16
WVZR-1
I added the " " to protect simpletons!! GOOGLE that "simpleton"
Then there's copy/paste if you can't TYPE!!
Old 11-13-2016   #17
lfalzarano
I found my plug at 20th Street Auto. Ask for Larry (800) 999-4911 X1003 or email partsdept@20thstreetauto.com. Mine was pulled from a standard C4 junker that I spotted online with the hood open.
Old 11-13-2016   #18
I will give them a holler thanks for that lead
