![]() Join Date: Oct 2010
94 zr1 with haibeck top end work. Headers, no cats.
Passed everything except the hc at idle. Allowable limit is 220. Tested 3 times, read 561, 260, and 461. Car sat for two years, I think I've run most of the bad gas through it, currently on second tank of fresh gas, added fuel system cleaner to both fill ups. Only issue with the way it runs is an off-idle stumble. Ideas? Thanks, Jack |
![]() Join Date: Mar 2007
move to another state
probably a tune someone could do for the test
Injectors going bad?
![]() Join Date: Feb 2006
put cats on it
Well, yeah, putting the cats back on is the obvious solution, but I've seen posts where they've passed without them. And it's fine at higher rpms. I'm thinking its related to letting the car sit. The way it acts from zero throttle to a little bit open, if it was carburator, I'd look at the accelerator pump. I don't know what the equivalent to that is with fuel injection. Was hoping to hear from someone very familiar with the fueling systems and what might be causing it to run rich just at idle. The car has only 19,000 miles, new plugs were put in about 2,000 miles ago. I hate to go the effort and expense replacing the injectors and then discover it doesn't run any differently. The secondaries are wired open, if that makes any difference.
![]() Join Date: Feb 2011
The tune is adding fuel and timing which will raise emissions, but you could still pass if you had the oem cats. Not having cats with a chip...you don't have a prayer. At least put a stock chip in it.
![]() Join Date: Feb 2012
Replace cats
#10 | |
