Old 10-21-2016   #1
Xdt
Default Where does it go?
Guys,
Currently installing new radiator, hoses and thermostat. However, I cannot remember where this plastic cover goes. I took photos of the plenum in order to replace injectors ands actuators but, figured I did not need photos for a simple radiator install. 😊
Thanks again for looking.
Xdt is offline   Reply With Quote
Old 10-21-2016   #2
Default Re: Where does it go?
fills the gap between the radiator and front of frame; many people remove it to let in fresh air, supposed to keep high water away from air filter
Old 10-21-2016   #3
from the solutions section:
4. Water Deflector
The Water Deflector which sits under the end of the OEM Air Box (or SS Air Box) to prevent water from being sucked into the Air Intake from the front grille. What it also does is prevent cooler air from entering the Air Intake from the grille. I deleted the Water Deflector from both the L98 and LT5 SS Air Box installations.
Old 10-21-2016   #4
Xdt
LGAFF,
Thank you for the reply, just what I needed.
Old 10-22-2016   #5
cvette98pacecar
It goes right in the trash. My air box is open on the bottom, when I get caught in the rain my pistons get real clean.
