![]() Join Date: Jul 2007
I have not looked at the 94-96 pump for repair purposes, but there is only one, mounted on the passenger side.
Unlike 93-older the pump runs both direction, inflate and deflate. if you have a 93-older, then in the center of the hard base there is a metal clip that can move backwards when pressure is applied tot he lower cushion, that will release the lower cushion and allow it to come out. be careful as the lines and port inlets maybe be brittle, more the inlets than the lines. then you will see the pumps.. again 93- older, each seat has a pump
