Old 09-29-2016   #1
Default LT5 Trademark
Apparently GM re-submitted Trademark application for LT5 engine designation.
On Corvette Action Center.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 09-29-2016   #2
efnfast
Default Re: LT5 Trademark
I don't understand why they reuse old monikers. Other than nostalgia.
Old 09-29-2016   #3
spork2367
Drives me nuts. Then every time you want to talk about an engine, you have to clarify which one (with non GM people anyway.).
Although if they'd put the new Mercury marine motor in, I'd be okay with it...
Old 09-29-2016   #4
edram454
edram454's Avatar
i hope they use the lt5 moniker again. i hope it is a kick *** car and raises awareness to our cars as the first gen lt5. it can only help our undervalued cars.
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 09-30-2016   #5
Hog
I hear you.
"Oh that LT1 engine, sure was a great engine."
"Uh which one, the 70's GEN 1 LT1 SBC, the 90's GEN 2 LT1 SBC or the 2014+ GEN 5 LT1 SBC?"
I guess there are only so many RPO codes available for use as an engine code as the rest of the RPO codes are used for other options like interiors, brakes, wheels and every other standard and optional component on the car.
And the confusion would not apply to the assembly plants where they are needed.
peace
Paul
