![]() Join Date: Nov 2014
Just to clarify, because I want to change next week,Castrol 10W-60 synthetic motor oil for the transmission fluid? 91Z...
Thanks.... |
![]() Join Date: Feb 2012
I would not use motor oil!
![]() Join Date: Feb 2009
Yes, that is correct, although Castrol has reformulated that oil. Not sure if it is the same.
Just to clarify, the Castrol 10W-60 is what ZF and Bill B. recommend for our transmissions. http://www.zfdoc.com/techinfo.htm Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 09-23-2016 at 10:40 AM. |
![]() Join Date: Jan 2010
Believe it or not, the last time I bought it, 2 years ago, the BMW stealership
was the least expensive! Including on line. BMW uses it as motor oil for various M series cars. |
![]() Join Date: Dec 2014
John, there four choices; Amsoil, Castrol, Redline, or ZF oil from Rockland Gear...they now own ZF. After my transmission was replaced due to "rare reverse spline lubrication failure" these were the recommended motor oils that must be used in our ZF transmissions, level checked, and changed at regular intervals.
I chose the Amsoil Manual Syncromesh 5w-30. A thicker viscosity would dampen gear chatter noise for a lightweight flywheel, but I just wanted a thinner faster moving oil for guaranteed lubrication. When filling, snake a hose from the top of the engine down to the fill hole, allow the excess to drip out from the fill plug hole till it settles, making sure car is level then insert plug. Trying to squeeze that extra love in there...winds up leaking out of the tailstock seal. 17mm stubby Allen impact socket if you need to borrow it. Last edited by George Maz; 09-24-2016 at 11:20 AM. Reason: added Redline oil |
![]() Join Date: Nov 2007
When I had my base 95 car, I too had that "rare reverse spline lubrication failure". Bill Boudreau reams the oil galleries out to a bit larger to (he said) assist w/ lubrication - as part of his "blue-printing" procedure on the ZF. But, he went on to say that if I opted not to have my replacement trans undergo his procedure, to be sure to use a synthetic oil.
The Castrol 10W-60 synthetic is no longer available (been re-formulated, as I understand it). But, as an alternative, Marc Haibeck recommended the Red Line High-Shock, synthetic gear oil as a substitute. My transmission is in need of a Boudreau "laying of hands". However, the crunching I sometimes get when shifting into 5th (especially when cold) is noticeably less since the switch to the RL product. This thread provides some new product info (to me). But, FWIW, I've driven 2 full seasons ≈ 7000 miles, and many WOT runs with the RL w/o problems. Last edited by Paul Workman; 09-24-2016 at 10:52 AM. Reason: punctuation |
#8 | |
Zf S6-40 Oil TIPS Castrol Edge Comparisons TIPS
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-24-2016 at 11:09 AM. |
