#51 |
Very cool ! ANy pics of the install underhood? I have been debating on going this route. If I keep my 93 stroker car I will go with n2o otherwise if I part that car out I will be building a big cube LT5. Maybe just add the n2o on top
#52 |
![]() Join Date: Jun 2013
#53 |
![]() Join Date: Mar 2007
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-08-2016 at 07:59 PM. |
#54 |
#55 |
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-17-2016 at 07:57 PM. |
#56 |
Do you need to run that standalone computer system or can you use the stock ECU?
#57 |
![]() Join Date: Jul 2010
Stock ECU works with any ECU, even the stock calibration would be fine with a wet 75hp shot. A window switch on the Port Throttles would be great, nitrous on ONLY when Port Throttles are in full swing.
#58 |
running stock system going to pull timing through IAT mod or a chip.....will find a better method through a switch after some testing....have to see if I blow the car up first
#59 |
#60 |
![]() Join Date: Jun 2005
I'm waiting with baited breath to see how a wet system works on an LT5.
When are you going to go to the chassis dyno?
